BPM how to loop through rows in tt table?
I’ve been trying to look up some example that would help my figure this out and I can’t figure out what I need so I am going to ask you guys.
How do I loop through rows in a BPM custom code block to build up a string? I’m trying to do it like I did for writing out CSV’s, but that was using a grid, so something doesn’t translate like I was hoping it would. This is the start of what I have, but I get an error.
    foreach(var row in ttShipDtl.Rows)
        string peice = string.Format("{0}{1}{2}{3}", row.ttShipDtl.OrderNum, row.ttShipDtl.OurShippedQty, row.ttShipDtl.PartNum, row.Email.LineDesc);
        mystring += mystring + peice;
CS1061 'ShipDtlTable' does not contain a definition for 'Table' and no extension method 'Table' accepting a first argument of type 'ShipDtlTable' could be found (are you missing a using directive or an assembly reference?)
So what am I doing wrong?
you can do it two ways…
  1. foreach ( var row in ttShipDtl)
    string peice = $"{row.OrderNum}{ row.OurShippedQty}…");
    mystring += peice;
  2. foreach (var row in (from shipDtlRow in ttShipDtl select shipDtlRow.))
    mystring += peice;
I was trying to do too much! thanks. Looking at your examples, I realized that I didn’t need the ttShipDtl in the “row.ttShipDtl.OrderNum” pieces. I took those out and now I get no errors. Looks like this.
foreach(var row in ttShipDtl)
    string peice = string.Format("{0}{1}{2}{3}", row.OrderNum, row.OurShippedQty, row.PartNum, row.LineDesc);
Whether is works or not, we’ll see…
You can’t use interpolated strings in a BPM (yet) :frowning:
Jose, What do you mean about the interpolated string usage in a BPM? I’ve been using code like this and it has been working fine. Did I misunderstand something?
mystring += String.Format("{0} {1}{2} {3}{4}   {5}{6}{7} {8}", orderNum.PadRight(9),counter+partNum.PadRight(20),bin.PadRight(8),partDesc.PadRight(32),qty.PadLeft(4),weight.PadRight(6,'0'),bin2.PadRight(15), country.PadRight(32), uom.PadRight(3));
Nathan
@Nathan_Woolen that works, I was referring specifically to the $“{var}” syntax referenced above by suteraj20. That’s C#6 and not yet available in most versions of E10 :frowning:
In later versions instead of doing what you typed
mystring += string.Format("My Formatted String: {0} {1}", varHello,varWorld);
You can do this
mystring += $"My Formatted String: {varHello} {varWorld}";
and “interpolate” the variables directly in the string. Which is uber awesome
@josecgomez I understand now. Thanks for the clarification.
Nathan
Didn’t realize that it was specific to 10.1.600??
So this is the final (kind of) result. I’ll be putting this into a simple auto e-mail and probably some other information.
Here’s the code in the code block
string mystring = "Order Num, Qty, Part number, Description"+ Environment.NewLine;
    string peice = string.Format("{0}      {1}  {2}   {3}", row.OrderNum, row.OurShippedQty, row.PartNum, row.LineDesc);
    mystring += peice + Environment.NewLine;
 this.OrderLineInfo = mystring;
You can shortcut the Enviornment.NewLine to “\n” if you would like…
string mystring = “Order Num, Qty, Part number, Description\n”;
mystring += peice + “\n”;
I believe you should be using “\r\n” if you chose to not use Environment.NewLine
