OK… to EXCLUDE HOLIDAYS, here is snippet of C# code that you can insert anywhere you need (BPM, etc)…
It calculates using one of the Epicor Calendars. It still assumes that Saturday and Sunday are non-work days, but it removes any holidays that are declared in the Shop Calendar you have specified.
I borrowed much of the logic from multiple sources on the internet, but also had to create my own little logic to use the Epicor calendar. Note that if you feed a starting date that is a weekend, it automatically moves it to the next working date.
While it seems odd to have to loop to do this calculation, I found no other clean way to do it… I did put some timers on this initially, and even when counting 1000s of days, the routine below only took a very brief number of milliseconds.
// Calculate Promise Date
// inputs:
// LeadTime = the lead DAYS you want to calculate
// StartingDate = the date you want to start counting form
// Outputs:
// pd = Promise date
string CalendarToUse = “Shipping” //change this to the epicor calendar you want to calculate against
DateTime pd = StartingDate ?? DateTime.Today; //promise date
bool WorkDay=true;
int RemainingDays = LeadTime+1; //add one to the leadtime
pd = pd.AddDays(-1); //make it yesterday
while (RemainingDays>0)
if (pd.DayOfWeek == DayOfWeek.Friday) pd=pd.AddDays(3);
else if (pd.DayOfWeek == DayOfWeek.Saturday) pd=pd.AddDays(2);
else if (pd.DayOfWeek == DayOfWeek.Sunday) pd=pd.AddDays(1);
else pd=pd.AddDays(1);
//now make sure that we are not on a holiday
var Holiday = Db.ProdCalDay.Where(r => r.CalendarID == CalendarToUse && r.ModifiedDay == pd).Select( row => new {row.ModifiedDay, row.WorkingDay} ).FirstOrDefault();
WorkDay = (Holiday == null)|| Holiday.WorkingDay; // WorkDay = true; else WorkDay=false;
if (WorkDay) RemainingDays -=1;
Inputs.ErrorText.Value +=string.Format("point1: {0} {1} {2}\n",pd,RemainingDays,(WorkDay)?"":"Holiday");
