BPM not setting Generate Suggestions to False when Runout = True
Hi guys,
I found an older BPM we had enabled that doesn’t seem to be working. When Runout = TRUE, it’s supposed to change the PartPlant.GenerateSugg field to FALSE. I put a message box which pops up when I set RunOut = TRUE, so the BPM is catching the condition.
Seems like a simple one, and since the ttPartPlant is in the Set Field widget dropdown, I thought it should work. My BPM crib notes mention using a Pre-Processing directive to set fields to the temp table. My widget to set the RunoutDate UD field is working fine when this is triggered…
Ideas? Thanks for the help.
Edit - I just did a trace on setting the Generate Sugg = False in Part Entry, and it used the PartImpl business object… I can try a separate BPM on that one, but then I’m confused why Update didn’t work…
  <businessObject>Erp.Proxy.BO.PartImpl</businessObject>
  <methodName>Update</methodName>
  <appServerUri>net.tcp://erpdb2/Pilot/</appServerUri>
  <returnType>System.Void</returnType>
  <localTime>5/4/2020 16:50:39:5121300 PM</localTime>
  <threadID>1</threadID>
  <correlationId>9e41b93d-d18f-483f-bfc4-945d09e1d372</correlationId>
  <executionTime total="678" roundTrip="591" channel="0" bpm="0" other="87" />
  <retries>0</retries>
  <parameters>
    <parameter name="ds" type="Erp.BO.PartDataSet">
      <PartDataSet xmlns="http://www.epicor.com/Ice/300/BO/Part/Part" />
    </parameter>
  </parameters>
  <paramDataSetChanges>
    <paramDataSet name="ds" useDataSetNbr="0">
      <changedValue tableName="PartPlant" rowState="Modified" rowNum="0" colName="GenerateSugg"><![CDATA[False]]></changedValue>
    </paramDataSet>
  </paramDataSetChanges>
  <serverTrace>
    <Op Utc="2020-05-04T20:50:39.7123638Z" act="Erp:BO:Part/PartSvcContract/Update" correlationId="9e41b93d-d18f-483f-bfc4-945d09e1d372" dur="581.061" cli="132.29.200.97:57843" usr="redacted" machine="redacted" pid="7032" tid="47" xmlns="">
      <BpmCustomization Source="DB" BpMethodCode="Erp.PartPlant" Type="In Transaction Trigger" Duration="33">
        <BpmDirective Type="0" ID="4c7b248b-605b-4624-9df7-7cb7ad63a5bc" Name="CL-PARTPLANT" VisibilityScope="0" Duration="33" />
      </BpmCustomization>
      <BpmCustomization Source="BO" BpMethodCode="Erp.Part.Update" Type="BO Customization" Duration="0">
        <BpmDirective Type="1" ID="ae36941c-1350-4f6e-9eab-b6923af4f6f6" Name="RunOutMRPPOSugg" VisibilityScope="0" Duration="0" />
        <BpmDirective Type="1" ID="bac60613-e4a7-469e-b5ad-07725527fd99" Name="PartTypeCodeChange" VisibilityScope="0" Duration="0" />
      </BpmCustomization>
    </Op>
  </serverTrace>
</tracePacket>
That BPM will not work, because when you update the PART table, the PartPLANT table is not being updated at the same time. Therefore, there will not be a “changed row” in the partplant to update.
In order to do what you want, you really should do a post-processsing update that also does the update on the PartPlant.
Tim - Thanks! I’ll give that a try.
You will probably need to call a Method Part.UpdateExt to do the update.
@timshuwy - Thank you. I’ll give that a try. How can I learn that UpdateExt is needed, when the trace shows PartImpl?
I found this:
Should I try this to keep everything in one BPM, or would I still need to do a separate Post with UpdateExt to change the PartPlant fields?
Thanks again!
to be 100% correct, you should do the UpdateEXT in a post processing BPM. You can trigger the post processing BPM based on events in the PRE processing.
