Thanks. Charlie. I will try using trace.
Best Regards,
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@...
607-754-9187 ext. 3078
www.ergpower.com
_____
Charlie Wilson
Sent: Thursday, October 29, 2009 7:11 AM
Subject: RE: [Vantage] BPM on JobHead Table
Have you tried to use tracing to see what BO is being called when you
manually make the change yourself?
When I made a change in job entry the BO jobentry.update was called.
<tracePacket>
<businessObject>Epicor.Mfg.BO.JobEntry</businessObject>
<methodName>Update</methodName>
<returnType>void</returnType>
<localTime>10/29/2009 07:08:15:3166596 AM</localTime>
<executionTime>578.5838</executionTime>
<parameters>
<parameter name='ds'
type='Epicor.Mfg.BO.JobEntryDataSet' ><JobEntryDataSet
xmlns="http://www.epicor
<http://www.epicor.com/Mfg/100/BO.JobEntry/JobEntry>
com/Mfg/100/BO.JobEntry/JobEntry">
~Charlie
_____
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
Herby Dallard
Sent: Thursday, October 29, 2009 6:14 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] BPM on JobHead Table
Good morning.
I am trying to implement a BPM mass update on a Job entry field
Jobhead.LockQty.
I have successfully processed a mass customer update on a checkbox field
using the customer update business object (BO) method code; however, there
is no (BO) or method code to perform an update on the Jobhead table. There
seem to only be BO for Job entry none of which includes an update.
Any code snippet and or direction would be greatly appreciated.
Thanks in advance.
Best Regards,
Herby Dallard
hdallard@ergpower. <mailto:hdallard%40ergpower.com> com
www.ergpower.com
Best Regards,
Herby Dallard
hdallard@...
www.ergpower.com
_____
Charlie Wilson
<tracePacket>
<parameters>
~Charlie
_____
Behalf Of
Herby Dallard
Good morning.
Jobhead.LockQty.
Thanks in advance.
Best Regards,
Herby Dallard
www.ergpower.com
