BPM - Post Process GetNewPORel LockQty=true 10.0.700.4
Hey,
I want to conditionally set the territory and sales rep fields on a new ship-to record based on the value of the customer ID. I entered a new post-process method directive for Erp.ShipTo.GetNewShipTo and dragged in a condition.
The post-process directive doesn't show a "The specified field of the changed row is equal...." as it does in pre-process.
So I tried "The custom code condition is valid." and entered "return ttShipTo.CustNumCustID == 1;"
When I enable and save it, I get:
"Server Side Exception
There is at least one compilation error.
Error Detail ============Description:  There is at least one compilation error.Details:  Error CS1061: 'Erp.Tablesets.ShipToTable' does not contain a definition for 'CustNumCustID' and no extension method 'CustNumCustID' accepting a first argument of type 'Erp.Tablesets.ShipToTable' could be found (are you missing a using directive or an assembly reference?) ..."
I can install a setter and reference ttShipTo.CustNumCustID, and I can refer to it in a pre-process directive condition.
The ICETools users guide didn't provide much illumination.
Am I on the wrong track?
Joe D. Trent
Bigham Ag Equipment
ttShipTo is a table so you need to loop into it. You can't just return ttShipTo.Field
On Wednesday, March 2, 2016, jdtrent@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Hey,</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">I want to conditionally set the territory and sales rep fields on a new ship-to record based on the value of the customer ID. I entered a <span style="margin:0px;padding:0px;outline:0px;vertical-align:baseline;">new </span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">post-process</span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;"> method directive for </span><span style="margin:0px;padding:0px;outline:0px;font-weight:inherit;font-style:inherit;font-family:inherit;vertical-align:baseline;background:transparent;">Erp.ShipTo.GetNewShipTo and dragged in a condition.</span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">The post-process directive doesn&#39;t show a &quot;The specified field of the changed row is equal....&quot; as it does in pre-process.</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">So I tried &quot;The custom code condition is valid.&quot; and entered &quot;return ttShipTo.CustNumCustID == 1;&quot;</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">When I enable and save it, I get:</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">&quot;Server Side Exception<br>There is at least one compilation error.<br>Exception caught in: Epicor.ServiceModel<br>Error Detail ============Description:  There is at least one compilation error.Details:  Error CS1061: &#39;Erp.Tablesets.ShipToTable&#39; does not contain a definition for &#39;CustNumCustID&#39; and no extension method &#39;CustNumCustID&#39; accepting a first argument of type &#39;Erp.Tablesets.ShipToTable&#39; could be found (are you missing a using directive or an assembly reference?) ...&quot;</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">I can install a setter and reference ttShipTo.CustNumCustID, and I can refer to it in a pre-process directive condition.</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">The ICETools users guide didn&#39;t provide much illumination.</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Am I on the wrong track?</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">--</p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Joe D. Trent</p><p><span></span></p><p style="margin-top:12px;margin-bottom:12px;outline:0px;font-family:Arial, Verdana, geneva, sans-serif;vertical-align:baseline;color:rgb(51,51,51);">Bigham Ag Equipment</p><p><span><br></span></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
Okay, thanks. I'll give it a shot.
Joe
On Wed, Mar 2, 2016 at 4:51 PM, Jose Gomez jose@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>ttShipTo is a table so you need to loop into it. You can&#39;t just return ttShipTo.Field<span class="ygrps-yiv-450760902"><span></span><br><br>On Wednesday, March 2, 2016, <a rel="nofollow" target="_blank" href="mailto:jdtrent@...">jdtrent@...</a> [vantage] &lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt; wrote:<br></span></p><blockquote class="ygrps-yiv-450760902gmail_quote" style="border-left:1px #ccc solid;">
Â
<div>
</div>
Jose C Gomez
Software Engineer
</div>
Dang. Well, I reused some code from another BPM to read the table, and it saved okay, but just never fired the exception. I've created two BPMs for use in creating and updating a ship-to record, and neither will fire a message or exception, even if I wire the message/exception box directly to the Start object.
I'm using these method directives:
Erp.ShipTo.GetNewShipTo/post-process/enabled
Erp.ShipTo.Update/pre-process/enabled
I looked at Erp.CustShip, but that looks like Customer Shipment to me.
I'm using similar BPMs on Erp.Customer.GetNewCustomer/post-process and Erp.Customer.Update/pre-process, and they work just fine.
Stumped. Is there another Ship-To object I'm not seeing?
Joe
Joe
Â
<div>
  <p>ttShipTo is a table so you need to loop into it. You can&#39;t just return ttShipTo.Field<span><span></span><br><br>On Wednesday, March 2, 2016, <a rel="nofollow" target="_blank" href="mailto:jdtrent@...">jdtrent@...</a> [vantage] &lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt; wrote:<br></span></p><blockquote class="ygrps-yiv-2117995373gmail_quote" style="border-left:1px #ccc solid;">
Â
<div>
</div>
Jose C Gomez
Software Engineer
</div>
The GetNewPORel method post-process directive does not set the PO Release LockQty to true. When I add another release, the checkbox gets checked on the second release but never on the first release. This is true for PO’s generated from the new PO suggestions program also.
In E10.0.700.4 data directives the PORel.LockQty field does not exists otherwise that would have worked probably.
Any help will be greatly appreciated.
MIKE TONOYAN | IT Director
MTonoyan@...
Tel +1.818.734.6511  |  Cell +1.818.397.8515
_________________________________________________________________________________ Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements. _________________________________________________________________________________
Hi Mike,
Lock qty and lock date is stored ComXref table. You can directly update it .
Regards,
Arul
Sent from my iPhone
On 5 Mar 2016, at 9:18 AM, Mike Tonoyan mtonoyan@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-2147347015ygrp-text">
  <p>
MTonoyan@...
</div>
In 10.1 they have finally moved the lock fields to the PORel table
This is how we do it in 10.0……
In Transaction Data Directive:
Condition: There is at least one added row in the PORel table
On true Execute Custom Code:
bool foundComxRefRecord = false;
string setLockDate = "No";
string setLockQty = "Yes";
Erp.Tables.COMXref COMXref;
foreach (var ttPORel_iterator in (from ttPORel_Row in ttPORel
                                  where ttPORel_Row.PORelNum != 0
                                  select ttPORel_Row))
    var ttPORelRow = ttPORel_iterator;
                                string strPO = ttPORelRow.PONum.ToString();
                                string strPOL = ttPORelRow.POLine.ToString();
                                string strPOR = ttPORelRow.PORelNum.ToString();
     COMXref = (from COMXref_Row in Db.COMXref
                where string.Compare(COMXref_Row.Company, ttPORelRow.Company, true) == 0
                && string.Compare(COMXref_Row.File, "PORel_Mapping", true) == 0
                && COMXref_Row.Key1 == strPO
                && COMXref_Row.Key2 == strPOL
                && COMXref_Row.Key3 == strPOR
                select COMXref_Row).FirstOrDefault();
     if (COMXref != null)
         COMXref.foreignKey1 = setLockDate;
         COMXref.foreignKey2 = setLockQty;
         foundComxRefRecord = true;
         Db.Release(ref COMXref);
     if (!foundComxRefRecord)
         COMXref = new Erp.Tables.COMXref();
         Db.COMXref.Insert(COMXref);
         COMXref.Company = ttPORelRow.Company;
         COMXref.File = "PORel_Mapping";
         COMXref.Key1 = System.Convert.ToString(ttPORelRow.PONum);
         COMXref.Key2 = System.Convert.ToString(ttPORelRow.POLine);
         COMXref.Key3 = System.Convert.ToString(ttPORelRow.PORelNum);
        Db.Validate();
Sent: Friday, March 04, 2016 5:18 PM
Subject: [Vantage] BPM - Post Process GetNewPORel LockQty=true 10.0.700.4
MTonoyan@...
Thanks Arul!
MTonoyan@...
Sent: Friday, March 04, 2016 4:34 PM
Subject: Re: [Vantage] BPM - Post Process GetNewPORel LockQty=true 10.0.700.4
Hi Mike,
Regards,
Arul
Sent from my iPhone
MTonoyan@...
Thanks Bernie!
MTonoyan@...
Sent: Friday, March 04, 2016 4:37 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] RE: BPM - Post Process GetNewPORel LockQty=true 10.0.700.4
        Db.Validate();
MTonoyan@...
Yes, we use it for MRP to suggest new POs instead of suggesting to reduce or increase the existing POs qty’s. We run MRP once a week in regenerative mode and it works for us. Never tested to run generate PO suggestions in net change. You need to run MRP Recalc Needed if you are running MRP in net change mode.
MTonoyan@...
Sent: Monday, March 07, 2016 11:41 AM
Subject: RE: [Vantage] BPM - Post Process GetNewPORel LockQty=true 10.0.700.4
Mike,
Could you help clarify what you are using the PO Release LockQty for?  We are using it so that any new PO suggestions will be generated if this locked qty and date checkboxes are checked on any prior PO suggestions for that part.  Is this how you are using the functionality also?  It seems like when we check both the lock qty and date checkboxes, we run the Generate PO Suggestions as Net Change but do not receive any new PO suggestions even after reviewing our demand forecasting.
Sent: Friday, March 04, 2016 4:18 PM
MTonoyan@...
