On Tue, Sep 29, 2015 at 12:05 PM, jdtrent@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>I tried this condition in the BPM Pre-Processing Directive:</p><div><br></div><div>Condition:</div><div>The ttPartPlant.QtyBearing field of the changed row is not equal to the ttPart.QtyBearing expression</div><div><br></div><div>Save result:</div><div><br></div><div><span class="ygrps-yiv-1737804136"><div>There is at least one compilation error.</div><div><br></div></span><div>Exception caught in: Epicor.ServiceModel</div><div><br></div><div>Error Detail </div><div>============</div><span class="ygrps-yiv-1737804136"><div>Description:  There is at least one compilation error.</div><div>Details:  </div></span><div>Error CS0136: A local variable named 'ttPartRow' cannot be declared in this scope because it would give a different meaning to 'ttPartRow', which is already used in a 'child' scope to denote something else [Part.Update.cs(663,17)]</div><div>Program:  Epicor.Customization.dll</div><div>Method:  PrepareException</div><div><br></div><div>It gave me a similar message if I reversed the fields.</div><div><br></div><div>Thanks,</div><div><br></div><div>Joe</div></div><div><br></div><p></p> </div> <div style="color:#fff;min-height:0;"></div>
Hi,
I'm trying to create a method directive BPM with custom code that forces the PartPlant QtyBearing field to match the Part QtyBearing field. If I try a test like:
bool NQBMismatch = false;
if (ttPartPlant.QtyBearing == true) {NQBMismatch = true;}
return NQBMismatch;
On save, I get the error:
Description: There is at least one compilation error.Details: Error CS1061: 'Erp.Tablesets.PartPlantTable' does not contain a definition for 'QtyBearing' and no extension method 'QtyBearing' accepting a first argument of type 'Erp.Tablesets.PartPlantTable' could be found
I can read ttPartPlant for the record as:
var ttPartPlantResult = (from row in ttPartPlant where row.Company == Session.CompanyID select new { row.PartNum, row.QtyBearing}).FirstOrDefault();
It looks like I get the original row, and not the changed row I trying to save.
How can I access fields from the current changed row in BPM custom code?
Joe
Joe D. Trent
Bigham Ag Equipment
Try this to get the updated or added row for PartPlant.
var ttPartPlant_xRow = (from ttPartPlant_Row in ttPartPlant
where (((string.Equals(ttPartPlant_Row.RowMod, IceRow.ROWSTATE_ADDED, StringComparison.OrdinalIgnoreCase)) || (string.Equals(ttPartPlant_Row.RowMod, IceRow.ROWSTATE_UPDATED, StringComparison.OrdinalIgnoreCase)))
select ttShipDtl_Row).FirstOrDefault();
My Parenthesis might be off, but that statement will get you the updated or added row.
Good luck
Once done, you will reference fields like this...
ttPartPlant_xRow["Checkbox02"] = false.
Etc....
On Mon, Sep 28, 2015 at 3:33 PM, amathis@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p>Once done, you will reference fields like this...</p><p><br></p><p>ttPartPlant_xRow["Checkbox02"] = false.</p><p>Etc....<br></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
On Mon, Sep 28, 2015 at 4:06 PM, amathis@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>I am curious though, you could probably do this without the custom code and just condition statements, and then use a throw exception balloon, but whatever works :)</p> </div><span class="ygrps-yiv-1686759964"> <div style="color:#fff;min-height:0;"></div>
