#ygrps-yiv-278783475 P.ygrps-yiv-278783475ce387540-7764-462c-979a-97379ccda45c {
MARGIN:0cm 0cm 0pt;}
#ygrps-yiv-278783475 LI.ygrps-yiv-278783475ce387540-7764-462c-979a-97379ccda45c {
#ygrps-yiv-278783475 DIV.ygrps-yiv-278783475ce387540-7764-462c-979a-97379ccda45c {
#ygrps-yiv-278783475 TABLE.ygrps-yiv-278783475ce387540-7764-462c-979a-97379ccda45cTable {
#ygrps-yiv-278783475 DIV.ygrps-yiv-278783475Section1 {
This is possible with a BPM and a BPM Form that is customised to ask the specific question.
Depending on the response you could then update the field.
Alternately this could be done all within the customisation layer.
I would lean towards customisation in this instance.
Sent: 29 May 2014 03:45
Subject: [Vantage] BPM to ask a question and update a field value
When we are working in PO Entry in 9.05.702a and select “Approved†we would like a question to come up asking:
Is this a New or Revised PO?
If they answer New – it would toggle the new radio button, otherwise the revised radio button would be selected.
Do you know if it’s possible to do this with a BPM or by going into customization mode and putting in some c# code? What might be an example of doing this?
Thanks.
Stephen Edginton (Beng)
| Solutions & Technical Director
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
