Hello
I would like to be able to prevent a sales order header from being saved if the timescale between the OrderHed.OrderDate and OrderHed.RequestDate (ShipBy) is less than 365 days and OrderHed.ShortChar01 contains the word Machine.
I have no idea how to write the 4GL Code to implement this.
The reason for this is that for our scheduling to work these sales orders are make to order and we do not want MRP to create planned orders for them in the immediate future, we have determined that the RequestDate (ShipBy) determines how the job will be scheduled. By making it 12 months away MRP will not create planned orders that affect anything now. We have MPS's in place for specific components that make up these orders.
I would appreciate any help that can be offered by the group.
We are on Vantage 410 Progress
Many thanks
Mark Lawrence
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St. | PO Box 279
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...
www.dsmfg.com<http://www.dsmfg.com>
Sent: Wednesday, November 18, 2015 5:07 AM
Subject: [Vantage] BPM to Raise Exception based on difference between 2 dates
Hello
Many thanks
Mark Lawrence
---In vantage@yahoogroups.com, <rbucek@...> wrote :
Rob Bucek
D&S Manufacturing
rbucek@...
Hello
Many thanks
Mark Lawrence
Rob Bucek
D&S Manufacturing
rbucek@...
Sent: Wednesday, November 18, 2015 9:01 AM
Subject: RE: [Vantage] BPM to Raise Exception based on difference between 2 dates
Hi Rob
Thanks for your reply
I have tried your suggestion but i do not have the option in pre-processing "The specified field on the changed row is equal to the specified expression" i only have "the specified field on the changed row is equal to the specific value"
I notice that your option is in ERP10 ( we are testing 10) and probably in 9 but it appears not to be in Vantage
Regards
Mark
You don’t really need 4gl to do what youre looking for, the method directive wizards/templates are all there for that. Create a method directive on SalesOrder.Update, preprocessing. Two conditions joined with ‘and’ the first use the option the specified field on the changed row is equal to the specified expression, where field is OrderHed.ShortChar01 and the expression is ‘Machine’. The second used the exact same option with field being OrderHed.OrderDate and the expression is Add-interval(Today, 365, ‘days’). Your action will be raise exception based on the designed template.
Rob Bucek
D&S Manufacturing
rbucek@...<mailto:rbucek@...>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Hello
Many thanks
Mark Lawrence
Rob Bucek
D&S Manufacturing
rbucek@...
Sent: Thursday, November 19, 2015 2:33 AM
Is it possible to do this in Vantage with some coding? We are not moving to Epicor 10 for at least 18 Months so this would be really useful at the moment.
thanks
Mark
Jose C Gomez
T: 904.469.1524 mobile
On Thu, Nov 19, 2015 at 3:32 AM, teaglem@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Is it possible to do this in Vantage with some coding? We are not moving to Epicor 10 for at least 18 Months so this would be really useful at the moment.</p><div><br></div><div>thanks</div><div><br></div><div>Mark</div><p></p> </div> <div style="color:#fff;min-height:0;"></div>
Jose C Gomez
On Fri, Nov 20, 2015 at 6:10 AM, teaglem@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Ok I think I spoke too soon.</p><div><br></div><div>It works well on new orders but if you go back to a previous order and say add a comment to the header it throws up message about the dates but then ignores any date you enter thus preventing saving of the order. I think the message about updating the release lines with the new Shipdates is causing the issue.</div><div><br></div><div>I have tried this in Job Entry as well where we have jobs prefixed by certain letters that need the same rule applied between the JobHead.createdate and JobHead.ReqDueDate. The rule is triggered correctly based on the job prefixes but the message pops up about the date regardless of what date is entered.</div><div><br></div><div>these are being entered in to SalesOrder,Update and JobEntry.Update as Pre-Processing methods.</div><div><br></div><div>Thanks</div><div><br></div><div>Mark</div><p></p> </div><span class="ygrps-yiv-1781474812"> <div style="color:#fff;min-height:0;"></div>
