Give this a shot
http://www.developerfusion.com/tools/convert/csharp-to-vb/
<http://www.developerfusion.com/tools/convert/csharp-to-vb/>Works pretty
well for the most part!
Sincerely
Jose C Gomez
http://www.josecgomez.com
Sincerely
Jose C Gomez
On Fri, Aug 13, 2010 at 3:44 AM, Mark <teaglem@...> wrote:
> Hi Jose
> I had another look at this and realised that in your Video you are using C#
> it appears that Version 8 doesn't support it and I don't know the .net
> equivalent.
> I will have to look at another way to do this or wait until we move to
> version 9.
> Many thanks for all your help
> Mark Lawrence
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Jose Gomez
> <jose@...> wrote:
> > You should be able to use the same code on AfterFieldChange under Form
> > Wizard. (Again if you have that option in 8)
> > Sincerely
> > Jose C Gomez
> > On Mon, Aug 9, 2010 at 7:44 AM, Jose Gomez <jose@...> wrote:
> > > Yeah that's what I was afraid of, we moved out of 8 a while back and
> > > couldn't remember if it was possible :(
> > > Sincerely
> > > Jose C Gomez
> > > On Mon, Aug 9, 2010 at 3:22 AM, Mark <teaglem@...> wrote:
> > >> Hi Jose
> > >> Great video, unfortunatly I am on 8 so the custom rule options are not
> > >> available, I will however see if I can copy the code you used into the
> form
> > >> and try that.
> > >> Many thanks
> > >> Mark Lawrence
> > >> Teagle Machinery Ltd
> > >> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> > >> <jose@> wrote:
> > >> > I am on 9 so I am not 100% sure if the steps are the same but here
> is a
> > >> > screen cap of how I am doing it, hope it helps.
> > >> > http://www.youtube.com/watch?v=Fdq1CZvmQ-U
> > >> > <http://www.youtube.com/watch?v=Fdq1CZvmQ-U>
> > >> > Sincerely
> > >> > Jose C Gomez
> > >> > On Thu, Aug 5, 2010 at 10:06 AM, Mark <teaglem@> wrote:
> > >> > > Hi Jose
> > >> > > Many thanks for your help, I am having a problem applying it as
> rule
> > >> in
> > >> > > form customization, is there a specific method for doing this?
> > >> > > Mark
> > >> > > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com><vantage%
> > >> > > <jose@> wrote:
> > >> > > > I would do a customization on the form, create a rule on
> ShortChar01
> > >> > > or
> > >> > > > whatever your ShortChar is
> > >> > > > Set the rule to validate using this function
> > >> > > > public static bool isValidEmail(string inputEmail)
> > >> > > > string strRegex = @"^([a-zA-Z0-9_\-\.]+)@((\[[0-9]{1,3}" +
> > >> > > > @"\.[0-9]{1,3}\.[0-9]{1,3}\.)|(([a-zA-Z0-9\-]+\" +
> > >> > > > @".)+))([a-zA-Z]{2,4}|[0-9]{1,3})(\]?)$";
> > >> > > > Regex re = new Regex(strRegex);
> > >> > > > if (re.IsMatch(inputEmail))
> > >> > > > return (true);
> > >> > > > else
> > >> > > > return (false);
> > >> > > > And the action to error
> > >> > > > Hope this helps!
> > >> > > > Sincerely
> > >> > > > Jose C Gomez
> > >> > > > mana
> > >> > > > On Thu, Aug 5, 2010 at 5:51 AM, Mark teaglem@ wrote:
> > >> > > > > Hi
> > >> > > > > I have some ShortChar UD fields in the Customer Entry form for
> > >> > > additional
> > >> > > > > e-mail addresses, unfortunately some users have added other
> > >> > > information into
> > >> > > > > them.
> > >> > > > > My question is this, with a BPM is there a way to raise an
> > >> exception
> > >> > > > > message if the field doesn't contain the "@" symbol, my hopes
> are
> > >> > > that this
> > >> > > > > will force people to use these fields for e-mail addresses
> only!
> > >> > > > > My 4GL knowledge is very limited so any help would be greatly
> > >> > > appreciated.
> > >> > > > > Vantage 8.03.405a Progress
> > >> > > > > Many thanks
> > >> > > > > Mark Lawrence
> > >> > > > [Non-text portions of this message have been removed]
