BPM - Write a basic file?
I’m starting the process of connecting Epicor to Bartender for labels. We think having Epicor generate text files will be a good solution to work with Bartender.
Question: What is the easiest way to generate a text file on a method? Some basic ABL code? Any examples for a very simple way to write “text.txt” with the content “here is a test”?
Thank you.
Here is a basic solution, if anyone ever needs one.
define variable fileLocation as character init ‘’.
define variable outputLine as character init ‘’.
assign fileLocation = “C:\temp\test.txt”.
output to value(fileLocation).
outputLine = “here is a test”.
message outputLine.
Output close.
