Bulk Export of BAQ's, Dashboards, Reports, and Customizations
We are starting our upgrade from E10 to SaaS and I am wondering if there is a way to do a bulk export of all our BAQ’s, Dashboards, Reports, and Customizations. I don’t mind doing it one at a time, but think there must be an easier way to import and then export in our new environment.
go into the SOLUTION MANAGER and create a “Solution,” and you can then make all these items as part of the solution. then you export the solution, which creates a CAB file. on the other side, you can import the solution which receives all teh customizations, into the new environment.
As @klincecum’s (unpaid) agent, I will again recommend:
I doubt it will work back that far, but I could probably whip something up that does without the pretty interface.
BAQ might be slightly difficult back that far, as I’m utilizing functionality they built for the web between now and then.
All good. If something requires installing, I barely have any rights anymore. Corporate took away IT admin rights except for one person. Makes no sense, but here we are. Don’t worry about making something just for me. I will just use the solution manager that Tim suggested. Thanks though. I did check it out and looks really nice.
