Button to Refresh All on Tracker in Dashboard
I inherited someone’s Dashboard and am being asked to fix the Clear button on the tracker portion of the dashboard. They claim that it used to work but now it does nothing when clicked. All that I actually need it to do is to execute a Refresh All (like pressing the white circle icon along the top). Can someone help me figure out how to make this button do that? Thank you!
This is the code that is there in Script Editor when Customizing the Tracker.
// Custom code for 54f2113e-302e-4539-a2f1-3c3b68881bcf
// Created: 7/24/2020 2:12:04 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public static class Script
	public static void InitializeCustomCode()
		Script.clearButton.Click += new System.EventHandler(Script.clearButton_Click);
	public static void DestroyCustomCode()
		Script.clearButton.Click -= new System.EventHandler(Script.clearButton_Click);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private static void clearButton_Click(object sender, System.EventArgs args)
		txtUD01_DiameterCode_c.Value = "";
		txtUD01_LeadCode_c.Value = "";
		txtUD01_Hand_c.Value = "";
		txtUD01_epicorPN_c.Value = "";
You should be able to do something like this:
MainController.AppControlPanel.HandleToolClick(RefreshTool, new Infragistics.Win.UltraWinToolbars.ToolClickEventArgs(MainController.MainToolManager.Tools[RefreshTool], null));
You can change that to RefreshAllTool if needed.
I tried changing it to that but I get this when trying to compile the dashboard:
## System Information ##
AppServer Connection: net.tcp://xxxxxxx/ERP102700-Live
Form Name: Dashboard
Customization Name:
Menu ID:
Software Version: 3.2.700.40
Application Error
## Error Detail ##
##!Message:##! --------compile errors------------
 Error: CS0117 - line 1022 (1021) - 'Ice.UI.App.ScrewThreadMaster.MainController' does not contain a definition for 'AppControlPanel'
 Error: CS0117 - line 1022 (1021) - 'Ice.UI.App.ScrewThreadMaster.MainController' does not contain a definition for 'MainToolManager'
 ** Compile Failed. **
##!Program:##!
##!Method:##!
I tried changing it to that, but when I do I get these errors when trying to compile the dashboard:
AppServer Connection: net.tcp://xxxxxxxx/ERP102700-Live
Customization Name:
Menu ID:
Application Error
## Error Detail ##
 Error: CS0103 - line 1022 (1021) - The name 'RefreshTool' does not exist in the current context
##!Program:##!
##!Method:##!
You aren’t trying to do the customization in the dashboard maintenance are you? This won’t work there. You need to go into the customization on the deployed dashboard.
Yes, I have been trying to do it in dashboard maintenance. Why is it that it can’t be done there?
It’s because it doesn’t have access to the rest of the form. Only what’s in the tracker window. The refresh or clear button is out of the scope of that customization.
Ah ok. Thank you for that. I had tried many options from Claude and Grok before coming here and none of them were working. This explains why.
