Calling Inventory Transfer from within Customization
Hello,
So I am having the same problem where I get an error that says "A Transfer Record was not found". My code looks like this...
InvTransferAdapter ita = new InvTransferAdapter(this.oTrans);
ita.BOConnect();
InvTransferDataSet itds = ita.GetTransferRecord("Test Part 1-1", "EA");
itds.Tables["InvTrans"].Rows[0]["RowMod"] = "A";
itds.Tables["InvTrans"].Rows[0]["ToWarehouseCode"] = "100002";
ita.ChangeToWhse(itds);
itds.Tables["InvTrans"].Rows[0]["ToBinNum"] = 1;
ita.ChangeToBin(itds);
itds.Tables["InvTrans"].Rows[0]["FromLotNumber"] = "1";
itds.Tables["InvTrans"].Rows[0]["ToLotNumber"] = "1";
ita.ChangeLot(itds);
itds.Tables["InvTrans"].Rows[0]["TransferQty"] = 3;
string out1, out2;
ita.CommitTransfer(itds, out out1, out out2);
ita.Dispose();
When I try running it with the Business Logic Test Tool, it works perfectly fine, but when attempting to run this code, it doesn't.
Thank you for the help!
--- In vantage@yahoogroups.com, "Kevin Simon" <ksimon@...> wrote:
> Joe,
> Worked great - thanks for the tip. I didn't realize there would be a
> difference in using the adapter versus the BO.
> Kevin
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Joe Rojas
> Sent: Wednesday, March 02, 2011 9:08 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Calling Inventory Transfer from within Customization
> Oh yeah. Don't forget:
> dsInvXF.Tables("InvTrans").Rows(0)("RowMod") = "A"
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> Of Joe Rojas
> Sent: Wednesday, March 02, 2011 8:51 AM
> Customization
> This is why I'm not a fan of adapters. :)
> The issue is that even though you are passing in a dataset, it's not
> actually using that dataset.
> Adapters act as wrappers for BOs and they also add some GUI capability
> to interact with the user.
> In this case, the InvTransferAdapter has its own internal tables that
> you need to set as opposed to setting them externally in dsInvXF.
> My opinion would be to which to the BO in this case.
> You code would look something like this:
> Dim boInvXf As InvTransfer = New InvTransfer(Not sure it oTran will
> work. I think you need a session.connectionpool)
> 'Get the transfer record
> Dim dsInvXf As InvTransferDataSet = boInvXf.GetTransferRecord(wkPN, "")
> MessageBox.Show("Got Transfer Rec " &
> dsInvXF.Tables("InvTrans").Rows(0)("FromBinNum") )
> dsInvXF.Tables("InvTrans").Rows(0)("FromBinNum") = wkFromBin
> dsInvXF.Tables("InvTrans").Rows(0)("ToBinNum") = wkToBin
> dsInvXF.Tables("InvTrans").Rows(0)("TransferQty") = wkTransQty
> boInvXf.CommitTransfer(dsInvXF, "", "") Second parameter is an "out"
> parameter. You need to pass it a variable so that it can store any
> messages.
> adInvXf.Dispose()
> adInvXf = Nothing
> Behalf
> Of Kevin Simon
> Sent: Tuesday, March 01, 2011 11:42 PM
> Customization
> Joe,
> Thanks for the help. Unfortunately, that's not the issue. I had already
> tried setting rowmod = "U" to no avail. So, I tried RowMod = "A", there
> was
> no difference.
> When I run a trace on it, there's simply nothing getting passed to the
> CommitTransfer. It's not that I see data in the dataset, there's nothing
> there. I've definitely got one row in the dataset, as I've verified
> through
> displaying data from it on the screen. However, when it executes the
> statement:
> Dim result As Boolean = adInvXf.CommitTransfer(dsInvXF, "", "")
> It's as if dsInvXF is empty.
> I took off the "dim result as Boolean =" from the statement, figuring if
> it
> failed it'd give me exception processing, but it simply displays nothing
> is
> there.
> If anyone has any ideas, or sample code that's doing a similar thing
> (initiating a transaction, then executing some type of commit), I'd
> truly
> appreciate it. I've done this tons of times with GetNew and Update type
> transactions.
> Thanks.
> Kevin Simon
> Behalf Of
> Joe Rojas
> Sent: Tuesday, March 01, 2011 12:03 PM
> Customization
> Hi Kevin,
> I never know when, or if, you have to use BeginEdit and EndEdit so it
> may or may not matter.
> With that said, the issue is that you are not setting RowMod = "A".
> Behalf
> Of Kevin Simon
> Sent: Tuesday, March 01, 2011 11:05 AM
> Customization
> Giving this a gentle nudge, anyone have any input?
> Behalf Of
> ksimon8fw
> Sent: Saturday, February 26, 2011 5:06 PM
> Subject: [Vantage] Calling Inventory Transfer from within Customization
> I've got a customization and I'm trying to create an inventory transfer
> from
> within it. I'm having a problem, it's getting the inventory transfer
> record,
> but when I do the CommitTransfer, it's telling me "A transfer record was
> not
> found".
> Here's the snippet of code I'm using:
> Dim adInvXf As InvTransferAdapter = New InvTransferAdapter(oTrans)
> adInvXf.BOConnect()
> Dim dsInvXf As InvTransferDataSet = adInvXf.GetTransferRecord(wkPN, "")
> adInvXf.Dispose()
> adInvXf = Nothing
> The MessageBox that I display is showing the GetTransferRecord is
> working
> properly, it's pulling up the defaults that I expect to see. When I run
> a
> trace on my code, it's showing that it's not passing anything back to
> the
> CommitTransfer, as if dsInvXF is blank. Is there something wrong with my
> syntax?
> Thanks.
> Kevin Simon
I've got a customization and I'm trying to create an inventory transfer from within it. I'm having a problem, it's getting the inventory transfer record, but when I do the CommitTransfer, it's telling me "A transfer record was not found".
adInvXf.BOConnect()
MessageBox.Show("Got Transfer Rec " & dsInvXF.Tables("InvTrans").Rows(0)("FromBinNum") )
adInvXf.Dispose()
adInvXf = Nothing
The MessageBox that I display is showing the GetTransferRecord is working properly, it's pulling up the defaults that I expect to see. When I run a trace on my code, it's showing that it's not passing anything back to the CommitTransfer, as if dsInvXF is blank. Is there something wrong with my syntax?
Thanks.
Kevin Simon
ksimon8fw
found".
adInvXf.BOConnect()
adInvXf.Dispose()
adInvXf = Nothing
syntax?
Thanks.
Kevin Simon
Hi Kevin,
Of Kevin Simon
Customization
Behalf Of
ksimon8fw
from
record,
not
found".
adInvXf.BOConnect()
adInvXf.Dispose()
adInvXf = Nothing
working
a
the
syntax?
Thanks.
Kevin Simon
Joe,
tried setting rowmod = "U" to no avail. So, I tried RowMod = "A", there was
no difference.
there. I've definitely got one row in the dataset, as I've verified through
statement:
I took off the "dim result as Boolean =" from the statement, figuring if it
failed it'd give me exception processing, but it simply displays nothing is
there.
(initiating a transaction, then executing some type of commit), I'd truly
transactions.
Thanks.
Kevin Simon
Joe Rojas
Hi Kevin,
Behalf
Of Kevin Simon
Customization
Behalf Of
ksimon8fw
from
record,
not
found".
adInvXf.BOConnect()
adInvXf.Dispose()
adInvXf = Nothing
working
a
the
syntax?
Thanks.
Kevin Simon
messages.
adInvXf.Dispose()
adInvXf = Nothing
Of Kevin Simon
Customization
Joe,
was
no difference.
through
statement:
it
is
there.
truly
transactions.
Thanks.
Kevin Simon
Behalf Of
Joe Rojas
Customization
Hi Kevin,
Behalf
Of Kevin Simon
Customization
Behalf Of
ksimon8fw
from
record,
not
found".
adInvXf.BOConnect()
adInvXf.Dispose()
adInvXf = Nothing
working
a
the
syntax?
Thanks.
Kevin Simon
Of Joe Rojas
Customization
messages.
adInvXf.Dispose()
adInvXf = Nothing
Behalf
Of Kevin Simon
Customization
Joe,
was
no difference.
through
statement:
it
is
there.
truly
transactions.
Thanks.
Kevin Simon
Behalf Of
Joe Rojas
Customization
Hi Kevin,
Behalf
Of Kevin Simon
Customization
Behalf Of
ksimon8fw
from
record,
not
found".
adInvXf.BOConnect()
adInvXf.Dispose()
adInvXf = Nothing
working
a
the
syntax?
Thanks.
Kevin Simon
I have a service connect workflow to accomplish this and I am performing more steps that what you are trying to use - I wonder if you need to call the other adapter methods in turn to make it work?
Get Transfer Record
Change From Bin
Change To Bin
Pre Commit Transfer
Commit Transfer
V8.03.405a
> Of Joe Rojas
> Customization
> messages.
> adInvXf.Dispose()
> adInvXf = Nothing
> Behalf
> Of Kevin Simon
> Customization
> Joe,
> was
> no difference.
> through
> statement:
> it
> is
> there.
> truly
> transactions.
> Thanks.
> Kevin Simon
> Behalf Of
> Joe Rojas
> Customization
> Hi Kevin,
> Behalf
> Of Kevin Simon
> Customization
> Behalf Of
> ksimon8fw
> from
> record,
> not
> found".
> adInvXf.BOConnect()
> adInvXf.Dispose()
> adInvXf = Nothing
> working
> a
> the
> syntax?
> Thanks.
> Kevin Simon
Hi Bernie,
I agree, the other method calls are used to validate and set default
values.
Does service connect work with the BO?
Of bw2868bond
Sent: Wednesday, March 02, 2011 9:22 AM
Subject: [Vantage] Re: Calling Inventory Transfer from within
Customization
Get Transfer Record
Change From Bin
Change To Bin
Pre Commit Transfer
Commit Transfer
V8.03.405a
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Joe
Behalf
> Of Joe Rojas
> Customization
> messages.
> adInvXf.Dispose()
> adInvXf = Nothing
> Behalf
> Of Kevin Simon
> Customization
> Joe,
already
there
> was
> no difference.
nothing
> through
> statement:
if
> it
nothing
> is
> there.
> truly
type
> transactions.
> Thanks.
> Kevin Simon
> Behalf Of
> Joe Rojas
> Customization
> Hi Kevin,
> Behalf
> Of Kevin Simon
> Customization
> Behalf Of
> ksimon8fw
Customization
transfer
> from
> record,
was
> not
> found".
> adInvXf.BOConnect()
> adInvXf.Dispose()
> adInvXf = Nothing
> working
run
> a
> the
my
> syntax?
> Thanks.
> Kevin Simon
It is my understanding that SC replaces the UI front end and works through the AD layer with the BO.
Also when passing parameters to the adapter calls, the field in the DS also needs to reflect the changed value.
Since we purchased the DMT, we have been using it to do the transfers :)
> Hi Bernie,
> values.
> Of bw2868bond
> Customization
> Get Transfer Record
> Change From Bin
> Change To Bin
> Pre Commit Transfer
> Commit Transfer
> V8.03.405a
> Behalf
> > Of Joe Rojas
> > Customization
> > messages.
> > adInvXf.Dispose()
> > adInvXf = Nothing
> > Behalf
> > Of Kevin Simon
> > Customization
> > Joe,
> already
> there
> > was
> > no difference.
> nothing
> > through
> > statement:
> if
> > it
> nothing
> > is
> > there.
> > truly
> type
> > transactions.
> > Thanks.
> > Kevin Simon
> > Behalf Of
> > Joe Rojas
> > Customization
> > Hi Kevin,
> > Behalf
> > Of Kevin Simon
> > Customization
> > Behalf Of
> > ksimon8fw
> Customization
> transfer
> > from
> > record,
> was
> > not
> > found".
> > adInvXf.BOConnect()
> > adInvXf.Dispose()
> > adInvXf = Nothing
> > working
> run
> > a
> > the
> my
> > syntax?
> > Thanks.
> > Kevin Simon
Bernie writes:
Does SC talk directly to the BOs or does it use the Web Services? (or either?)
I always suspected that SC talked to the web services which call
asp.net routines on the web server that in turn call the BOs. I
figured the reason why DMT is so much faster than SC is because there
isn't all of that marshaling/un-marshaling of data on each function
call.
Than again, I could be wrong. Just ask my wife...
Mark W.
Mark,
Yes, Service Connect indeed uses the web services.
By the way, you're right this once. Sorry, according to your wife, you used
up your one right answer for the year on this board.
Kevin
Mark Wonsil
Sent: Wednesday, March 02, 2011 10:58 AM
Subject: Re: [Vantage] Re: Calling Inventory Transfer from within
Customization
Bernie writes:
either?)
call.
Mark W.
Kevin writes:
Nope. I spelled 'Then' wrong. I'm still good for the year!
Joe,
Kevin
Joe Rojas
Behalf
Of Joe Rojas
Customization
messages.
adInvXf.Dispose()
adInvXf = Nothing
Behalf
Of Kevin Simon
Customization
Joe,
was
no difference.
through
statement:
it
is
there.
truly
transactions.
Thanks.
Kevin Simon
Behalf Of
Joe Rojas
Customization
Hi Kevin,
Behalf
Of Kevin Simon
Customization
Behalf Of
ksimon8fw
from
record,
not
found".
adInvXf.BOConnect()
adInvXf.Dispose()
adInvXf = Nothing
working
a
the
syntax?
Thanks.
Kevin Simon
