You can't access the Epicor.Mfg.Rpt.* dlls as web services, only the
Epicor.Mfg.Bo.* ones.
In Vantage 8 I've printer packing slips from service connect by using a
BAM to do the actual print job. This worked very well for awhile. In a
recent patch Epicor changed some of the logic in the system monitor and
I had to be very creative to get it working again. After that struggle
I'm not sure if I'll use a BAM again the next time I need to do this, or
come up with a cleaner method.
Either way I think you'll usually run into System Monitor issues with
printing from service connect. The system monitor is what actually
launches Crystal to print the report, and Service Connect doesn't have a
System Monitor.
It might be possible to avoid this problem in a E9 install by using the
server side Crystal runtime that the web client uses.
Good luck!
Brian Johnson -- Epi-Center <http://epi-ctr.com>
Director of Technical Services | direct: 413-531-2859
System Monitor.
Good luck!
On 02/01/2010 04:13 PM, Michelle de la Vega wrote:
> Is there a way to automatically print a job traveler using service
> connect? I traced the process and it uses the method rpt.jobtrav but I
> can't find that service in WS-Config.
> Has anyone out there done this before?
> Any help would be greatly appreciated.
> Thanks,
> Michelle de la Vega
> Business Applications Manager
> Cold Jet, LLC
> 455 Wards Corner Road
> Loveland, Ohio 45140
> USA
> +1 513-716-6400 (office)
> +1 513-382-3281 (mobile)
> +1 513-831-1209 (fax)
> www.coldjet.com<http://www.coldjet.com <http://www.coldjet.com>>
> [cid:image001.jpg@01CAA359.8605BBE0
> <mailto:image001.jpg%4001CAA359.8605BBE0>]
