<div id="ygrps-yiv-1741271493yiv5657979198ygrp-text">
<div dir="ltr"><div style="font-family:verdana, sans-serif;font-size:small;" class="ygrps-yiv-1741271493yiv5657979198gmail_default">Add that string as the last parameter sent to the email function. Currently its "" for your code.</div></div><div class="ygrps-yiv-1741271493yiv5657979198gmail_extra">
Jose C Gomez
T: 904.469.1524 mobile
On Mon, Nov 4, 2013 at 12:37 PM, Marc Livingston <livingstonmh@...> wrote:<div> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:12pt;"><div><span>How would the code look to achieve this? </span></div><div><span>I do not know what the handle will accept:</span></div>define variable vFrom as character no-undo initial '':U.define
variable vTo as character no-undo initial '':U.define
variable vCC as character no-undo initial '':U.define
variable vSubject as character no-undo initial '':U.define
variable vBody as character no-undo initial '':U.define
variable hEmailEx as handle no-undo.run
Bpm/BpmEmail.p persistent set hEmailEx.define
variable from_cnt as integer no-undo.define
variable to_cnt as integer no-undo.define
variable cc_cnt as integer no-undo.define
variable subject_cnt as integer no-undo.define
variable body_cnt as integer no-undo.assign
vFrom = ''vTo =
'Email Address 'vCC =
vSubject =vBody
=run
SendEmail in hEmailEx (false,
CUR-COMP,vFrom,vTo,vCC,
vSubject,vBody,
"":U)./* async as logicalcompany as characteremailFrom as characteremailTo as characteremailCC as characteremailSubject as characteremailText as characteremailMimeHeader as character */if
valid-handle(hEmailEx) then do:
delete procedure hEmailEx.
leave.
End.
On Monday, November 4, 2013 11:27 AM, Jose Gomez <jose@...> wrote:
<div> <div dir="ltr"><div style="font-family:verdana, sans-serif;font-size:small;"><span style="color:rgb(51, 51, 51);font-family:Menlo, Monaco, Consolas,;">"type=text/html:charset=us-</span><span style="color:rgb(51, 51, 51);font-family:Menlo, Monaco, Consolas,;">ascii:filetype=ascii"</span><br clear="none">
On Mon, Nov 4, 2013 at 11:32 AM, <livingstonmh@...> wrote:
<div> <div>Does anyone know how to change the MIME Content type from text/plain to text/html ?</div><div> </div><div>I have been using the code provided in an answer book, but I can't seem to get this working.<var></var></div> </div> <div style="color:rgb(255, 255, 255);"></div></div> <div><div style="color:rgb(255, 255, 255);"></div></div></div> <div style="color:rgb(255, 255, 255);"></div>
</div>
<div id="ygrps-yiv-1741271493yiv5657979198yqt06100" class="ygrps-yiv-1741271493yiv5657979198yqt7355178602"><div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mkp #ygrps-yiv-1741271493yiv5657979198hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mkp #ygrps-yiv-1741271493yiv5657979198ads {
margin-bottom:10px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mkp .ygrps-yiv-1741271493yiv5657979198ad {
padding:0 0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mkp .ygrps-yiv-1741271493yiv5657979198ad p {
margin:0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mkp .ygrps-yiv-1741271493yiv5657979198ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-sponsor #ygrps-yiv-1741271493yiv5657979198ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-sponsor #ygrps-yiv-1741271493yiv5657979198ygrp-lc #ygrps-yiv-1741271493yiv5657979198hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-sponsor #ygrps-yiv-1741271493yiv5657979198ygrp-lc .ygrps-yiv-1741271493yiv5657979198ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198activity span {
font-weight:700;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198activity span span {
color:#ff7900;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198activity span .ygrps-yiv-1741271493yiv5657979198underline {
text-decoration:underline;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198attach div a {
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198attach label a {
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198bold a {
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 dd.ygrps-yiv-1741271493yiv5657979198last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 dd.ygrps-yiv-1741271493yiv5657979198last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 dd.ygrps-yiv-1741271493yiv5657979198last p span.ygrps-yiv-1741271493yiv5657979198yshortcuts {
margin-right:0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198attach-table div div a {
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198attach-table {
width:400px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198file-title a, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198file-title a:active, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198file-title a:hover, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198file-title a:visited {
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198photo-title a, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198photo-title a:active, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198photo-title a:hover, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div.ygrps-yiv-1741271493yiv5657979198photo-title a:visited {
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 div#ygrps-yiv-1741271493yiv5657979198ygrp-mlmsg #ygrps-yiv-1741271493yiv5657979198ygrp-msg p a span.ygrps-yiv-1741271493yiv5657979198yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198green {
color:#628c2a;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 o {
font-size:0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198photos div {
float:left;width:72px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198reco-category {
font-size:77%;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198reco-desc {
font-size:77%;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 .ygrps-yiv-1741271493yiv5657979198replbq {
margin:4px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mlmsg select, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 input, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mlmsg pre, #ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 code {
font:115% monospace;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-mlmsg #ygrps-yiv-1741271493yiv5657979198logo {
padding-bottom:10px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-msg p#ygrps-yiv-1741271493yiv5657979198attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-reco #ygrps-yiv-1741271493yiv5657979198reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-sponsor #ygrps-yiv-1741271493yiv5657979198ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-sponsor #ygrps-yiv-1741271493yiv5657979198ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-sponsor #ygrps-yiv-1741271493yiv5657979198ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1741271493 #ygrps-yiv-1741271493yiv5657979198 #ygrps-yiv-1741271493yiv5657979198ygrp-vital ul li:last-child {
border-right:none !important;}
