Using a BPM on PO.Update, and Post Processing, I check with condition:
Method changed the ttPORelDueDate field of the ttPORel query from any to another.
Then I set another custom field.
But if you are at Header and change Due Date that way, let it cascade down to update all lines/releases, then it will not trigger that Condition in Post processing.
How to I trap the to see that if POREL.DueDate changes in this case?
Yes, the names in traces aren’t exact matches to names in directives.
BO.POImpl will correspond to Erp.PO
I might start with PO.Update - adding simple Pre and Post messageboxes and field(s) I’m interested in.
By coincidence I happen to be working on a date issue myself. Checking Dates on PO entry can be “interesting”, since there are many scenarios with different Method directives involved depending on entry sequence.
Why as Calvin mentioned, you might want to try a data directive instead.
Here are some of the methods I’ve been playing with.
How in a condition do you check, “Is POREL.DueDate a valid date” ?
I’m trying to trap this:
PO Release Due Date changes from one valid date to another date.
Valid date to Valid date = TRUE
Empty date to Valid date = FALSE
Empty date to Empty date = FALSE
Null to Any doesn’t seem to trigger, so I’m guessing a date is not null?
TEST 1:
Condition:
ttPORel.DueDate field of the CHANGED row is more than 1/1/1900.
with a show message of TRUE for true and FALSE for false
I go to the PO, add a line, put a part and a qty, the line takes the header Due Date by default.
I save it and first pops up a TRUE message, i.e. the porel.duedate of all rows
click OK and get a second TRUE one.
TEST 2:
ttPORel.DueDate field of the ADDED row is more than 1/1/1900.
Go to PO, add a line, put part and qty, line takes header Due Date by default
Save it and again a TRUE message, i.e. a valid due date > 1/1/1900.
Click OK and get a FALSE.
Why does the condition trigger twice?
I’m not adding more than one row.
Why does the Added reply first say true, your due date is > 1/1/1900
and then false that it does not?
