I have the following code and am getting the compiler errors listed. Does anyone know what I can do to resolve this?
Erp.BO.KanbanReceiptsDataSet kanbanDS;
using (var svc = WCFServiceSupport.CreateImpl<Erp.Proxy.BO.KanbanReceiptsImpl>(session, Epicor.ServiceModel.Channels.ImplBase<Erp.Contracts.KanbanReceiptsSvcContract>.UriPath))
Erp.BO.SelectSerialNumbersParamsDataSet dsSNDS = new
Erp.BO.SelectSerialNumbersParamsDataSet();
dsSNDS = svc.GetSelectSerialNumbersParams(kanbanDS);
Error: CS0433 - line 361 (913) - The type ‘Erp.BO.SelectSerialNumbersParamsDataSet’ exists in both ‘c:\Epicor\ERP10.1.600.16Test\Client\Erp.Contracts.BO.KanbanReceipts.dll’ and ‘c:\Epicor\ERP10.1.600.16Test\Client\Erp.Contracts.BO.SelectedSerialNumbers.dll’
It’s a known issue and @edge just recently mentioned on this list that Epicor are working on it. There’s a proxy solution on EpicCare or you can do some of the work in code.
Ok. I am trying to Create a Serial Number through customization and it isn’t working. I have the code causing this compiler error commented out. Could this be a reason I am not able to create my serial number?
And what about that product’s workflow can’t use Epicor’s built-in serial number generator? When in the process do you issue the serial number? Before manufacturing? After manufacturing? Are you purchasing and reselling a serialized product?
I don’t know those things. I was just mandated to do it. They want a new screen that will, among other functions, create serial numbers and assign them to jobs.
