We’re testing our product configuration after upgrading out test environment from 10.2.300.12 to 10.2.500.8, and I received a compile error in Quote Entry. I’m no programmer, but did take @timshuwy’s Configurator course at Insights.
I started following this error down the rabbit hole:
- Opened 'SHADE’in Configurator Designer > Actions > Test Inputs, and got the same error
- I see the same error when I open the event expression in the On Save tab editor, and check syntax.
Description: There is at least one compilation error.
Details:
_SHADEServerEvents.cs(57,69): error CS7036: There is no argument given that corresponds to the required formal parameter 'dataContext' of 'ServiceRenderer.GetService<TContract>(IceDataContext, bool)'
_SHADEServerEvents.cs(72,69): error CS7036: There is no argument given that corresponds to the required formal parameter 'dataContext' of 'ServiceRenderer.GetService<TContract>(IceDataContext, bool)'
Program: Epicor.Customization.Core.dll
Method: Compile
Line Number: 78
Column Number: 13
This family of configurators was created a few years ago, before my time. What does that error message mean, and how do I fix it? Did something change between 10.2.300 and 10.2.500 for these two lines?
using (var svc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.SalesOrderSvcContract>())
What’s odd is that the error calls out Line 78, but looking at the code in Notepadd++, it only has 52 lines, and those two ‘using’ lines are 17 and 32.
Thanks for any help!
// re-enable BPM methods
string entityName = OnSaveArgs.TargetEntity.EntitySetName;
string partNum = (string) OnSaveArgs.TargetEntity["PartNum"];
var partWeight = (from row in Db.Part
where row.Company == "ESAPCO" &&
row.PartNum == partNum
select row.NetWeight).FirstOrDefault();
decimal lineWeight = (decimal)OnSaveArgs.TargetEntity["LineWeight_c"];
decimal newLineWeight = (partWeight * Inputs.epiPcNumericEditor3.Value) + (partWeight * Inputs.epiPcNumericEditor19.Value);
if (newLineWeight != lineWeight)
if (entityName == "OrderDtl")
var orderNum = (int)OnSaveArgs.TargetEntity["OrderNum"];
var orderLine = (int)OnSaveArgs.TargetEntity["OrderLine"];
var dataSet = svc.GetByID(orderNum);
var dbDtl = dataSet.OrderDtl.Find(l => l.OrderLine == orderLine);
dbDtl["LineWeight_c"] = newLineWeight;
dbDtl.RowMod = "U";
dataSet.OHOrderMsc.Clear();
dataSet.OrderMsc.Clear();
dataSet.OrderHed.Clear();
svc.Update(ref dataSet);
} else if (entityName == "QuoteDtl")
using (var svc = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.QuoteSvcContract>())
var orderNum = (int)OnSaveArgs.TargetEntity["QuoteNum"];
var orderLine = (int)OnSaveArgs.TargetEntity["QuoteLine"];
//var dbDtl = dataSet.QuoteDtl.Find(l => l.QuoteLine == orderLine);
//dbDtl["LineWeight_c"] = newLineWeight;
//dbDtl.RowMod = "U";
dataSet.QuoteHed.FirstOrDefault().RowMod = "U";
dataSet.QuoteDtl.Clear();
dataSet.QuoteCoPart.Clear();
dataSet.QSalesRP.Clear();
dataSet.QuoteQty.Clear();
dataSet.QuoteHedMsc.Clear();
dataSet.QuoteMsc.Clear();
// dataSet.QuoteHed.Clear();
