Convert Time Field to HH:MM:SS
Easy question for the early riser today! lol
Not sure why I’m having such problems with this, but I want to just take a simple field (ShipHead.ChangeTime), and convert it from “28189” to something legible.
I’m assuming somewhere within the calculated fields of a BAQ I can accomplish this?
Check this out.
It is two fields from PartTran called SysDate and SysTime and @hkeric.wci is using both to come up with a formatted datetime.
Stupid question…
Are these then put into a calculated field to display in a BAQ? I’m guessing I can do something similar since I can use ShipHead.ChangeDate and ShipHead.ChangeTime?
I only need the time, but whatever works I will take.
I have set up a calculated field with a Data Type of datetime and use the following calculation
convert(datetime, ((datediff(day,‘01/01/1900’ , ShipHead.ChangeDate))+(convert(decimal, ShipHead.ChangeTime)/86400)))
Yeah it would be in a calculated field.
I use a quick nvarchar calculated field in the BAQ:
	CONVERT(varchar, DATEADD(ss, PartTran.SysTime, 0), 8)
Style 8 gives HH:MM:SS, while 14 or 114 gives HH:MM:SS:MMMM (milliseconds)
FYI, SysTime is seconds after midnight.
Thanks, Andris.
Don’t know why I had problems with doing this, but this worked on the first try.
Nice Andris, I am sure this post will be a favorite for years to come.
