Converting 8.03.305 to 8.03.4xx on New Virtual Server
Nevermind...Windows firewall on the server was blocking it. Thanks for the help
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Tellefson
Sent: Thursday, October 13, 2011 8:26 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: Converting 8.03.305 to 8.03.4xx on New Virtual Server
Thanks Ned. I have apparently been stuck on 8.03.305 too long. I forgot all these steps. I was able to log into the admin tools on the server and ran the necessary conversions. I can now log in to the client on the server.
The same problem is still happening on my workstation though. I right clicked on the app server and saw it was port 8301 and then checked the default.mfgsys file on my workstation and the app server is listed as epicor80340x:8301 which is the correct server name and port. Any other ideas what I might be missing?
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Ned
Sent: Wednesday, October 12, 2011 5:38 PM
Have you logged into the Admin Tools and run the conversions?
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
Mark Tellefson
Sent: Wednesday, October 12, 2011 6:34 PM
To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
Subject: Re: [Vantage] Re: Converting 8.03.305 to 8.03.4xx on New Virtual
Server
I ran the schema change per instructions and applied the latest patches.
What other conversions would need to be run?
Sent from my iPhone
On Oct 12, 2011, at 5:24 PM, "Ned"
<TechnoBabbly@...<mailto:TechnoBabbly%40gmail.com><mailto:TechnoBabbly%40gmail.com><mailto:TechnoBabbly@...<mailto:TechnoBabbly%40gmail.com><mailto:TechnoBabbly%40gmail.com>>> wrote:
You need to run schema changes and conversions before you can login with a
client.
Also be sure that the ports in the .mfgsys files are the same as on your
server.
Ned
Alternative Technology Partners
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
[mailto:<mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:van
tage@yahoogroups.com<mailto:tage%40yahoogroups.com><mailto:tage%40yahoogroups.com>>] On Behalf Of Mark Tellefson
Sent: Wednesday, October 12, 2011 5:51 PM
To:
'<mailto:%27vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage
@yahoogroups.com>'
Server
Next problem...Running the client on my computer it ran through the copying
all the files to my client directory but then errors out saying that the app
server didn't respond in time. The AdminService is running. The app servers
are running and the database is running. When I try to run the client on the
server it says the system needs to be upgraded.
Sent: Wednesday, October 12, 2011 3:59 PM
To:
@yahoogroups.com>'
Server
Not sure what I did different but I walked back through the steps below
again and it appears to be working. Thanks for the help.
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>><mailto:vantage%40yah
oogroups.com>
tage@yahoogroups.com<mailto:tage%40yahoogroups.com><mailto:tage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com>] On Behalf Of Mark
Tellefson
Sent: Wednesday, October 12, 2011 2:26 PM
To:
@yahoogroups.com><mailto:%27vantage%40yahoogroups.com>'
Server
Thanks Ned....fixed the PET problem
Still the same problem with prorest. Here is what I tried:
I removed everything from the epicor\mfgsys803\db directory on new server On
the old server I ran "prostrct repair mfgsys" in the epicor\Pilot803\db
directory Ran probkup in the Pilot803 directory (created PilotBkup.1 that is
about 3G) Copied PilotBkup.1 to the epicor\mfgsys803\db directory on new
server Ran "prorest mfgsys PilotBkup.1" in the mfgsys803\db folder Received
the same error as posted before.
I also tried copying the LiveBkup.1 file that was created as part of last
night's backup using the same process and got same result.
<mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage@yah
oogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40y
ahoogroups.com<http://ahoogroups.com>>
tage@yahoogroups.com<mailto:tage%40yahoogroups.com><mailto:tage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com><mailto:van
tage%40yahoogroups.com>] On Behalf Of cooner_55421
Sent: Wednesday, October 12, 2011 11:50 AM
To:
Subject: [Vantage] Re: Converting 8.03.305 to 8.03.4xx on New Virtual Server
OK, this should go simply but maybe something was missed or out of sequence.
> > I copied our live database to the Pilot database
>> and then ran the truncate function which appeared to run fine
By copy, do you mean probkup, move backup file and then use prorest?
If so, can you also try "prostrct repair mfgsys"?
Then try to backup and restore...
And, why not wait to truncate until you get this backed up and restored over
to the new server?
--- In
ahoogroups.com<http://ahoogroups.com>><mailto:vantage%40yahoogroups.com>,
Mark Tellefson
<mtellefson@...<mailto:mtellefson@...<mailto:mtellefson@...%3cmailto:mtellef
son@...<mailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@..
.%3cmailto:mtellefson@...<mailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellef%0bson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@..%0b.%3cmailto:mtellefson@...<mailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellef%0bson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@..%0b.%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellef%0bson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@..%0b.%3cmailto:mtellefson@...>>>>>> wrote:
> I deleted everything in the db directory and still get the same error.
> One
other strange thing I ran into is when I try to run the Progress Explorer
tool I get an error that the mmc has stopped responding.
> From:
<mailto:vanta%20%0b<mailto:vanta%0b%3cmailto:vanta%20%0b>>> ge%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> to:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com><mail
> Sent: Wednesday, October 12, 2011 10:56 AM
> To:
> Server
> Sometimes this happens when moving from one location to another if
> there
are already files in the new directory.
> The prerest tries to match them before proceeding.
> You can delete (or move) any files that were in that directory & try
preorest again.
> --- In
ahoogroups.com<http://ahoogroups.com>><mailto:vantage%40yahoogroups.com><mai
ps.com<http://ps.com>>, Mark Tellefson <mtellefson@<mailto:mtellefson@>>
wrote:
> > I copied our live database to the Pilot database and then ran the
truncate function which appeared to run fine (no errors). I then used
ProBkUp to backup the Pilot database. I copied it to the new server 8.03.4xx
mfgsys database. When I try to use ProRest to restore it there I get the
following error:
> > This backup of a 32-bit DBKEY database contains BI to TL data. It
> > cannot
be restored by the 64-bit DBKEY codebase (13732) Use the 10.1A prorest
utility to restore the database.
> > The new server is server 2008 32-bit so I am not sure where the
> > 64-bit
reference is coming from. I thought I would be able to restore it there and
then run the schema change. What am I missing?
> > From:
<mailto:van%20%0b<mailto:van%0b%3cmailto:van%20%0b>>> > tage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:van
<mailto:van%0b<mailto:van%0b%3cmailto:van%0b>>> > tage%40yahoogroups.com>
> > ilto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com><ma
> > ilto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> > Sent: Tuesday, October 11, 2011 2:27 PM
> > To:
> > Virtual Server
> > For a test, I think I would stay away from the production database.
> > I always use a separate server to test upgrades & patches.
> > It should be easy to make a backup copy of the production db, then
truncate the copy.
> > BTW... here is a ProgressTalk thread on truncating:
> > <http://www.progresstalk.com/showthread.php?114471-truncating-BI>
> > --- In
ps.com<http://ps.com>><mailto:vantage%40yahoogroups.com>, "Mark"
<mtellefson@> wrote:
> > > I am working on the intermediate step of coverting from 803.305 to
8.03.4xx before testing the new conversion tool to 9. In the instructions
the steps to convert the database are kinda confusing. It says I need to
truncate the bi (before image) before restoring it to the new server. My
concern is that it will damage the live database. Am I correct in this plan?
> > > run "proutil mfgsys -C truncate bi" on the existing server (do I
> > > need to stop all app servers?)
> > > Use ProBkUp to backup existing database
> > > Copy the backup file to the new server db directory
> > > Use ProRest to restore database on new server
> > > Launch client and run schema changes
> > > Any other thoughts or concerns? Thanks
> > __________________________________________________________
> > [<http://www.rapat.com/download/logoflat.jpg>http://www.rapat.com/do
> > wnload/logoflat.jpg]<<http://www.rapat.com>http://www.rapat.com>
> > Mark Tellefson | Global IT Director |
> > www.rapat.com<http://www.rapat.com><<http://www.rapat.com>http://www
> > .rapat.com>
> > Phone: (218) 483-3344 | Toll Free: (800) 325-6377
> > Confidentiality Notice: This e-mail message, including any
> > attachments,
is for the sole use of the intended recipient(s) and may contain
confidential and privileged information. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are not the intended
recipient and received this in error, please contact the sender by reply
e-mail. You are hereby notified that the copying, use or distribution of any
information or materials transmitted in or with this message is strictly
prohibited.
<http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>>http://groups.yahoo.com/group
/vantage/files/.
<http://groups.yahoo.com/group/vantage/messages>http://groups.yahoo.com/grou
p/vantage/messages
<http://groups.yahoo.com/group/vantage/linksYahoo>http://groups.yahoo.com/gr
oup/vantage/linksYahoo! Groups Links
[http://www.rapat.com/download/logoflat.jpg]<http://www.rapat.com>
Mark Tellefson | Global IT Director | www.rapat.com<http://www.rapat.com>
Confidentiality Notice: This e-mail message, including any attachments, is
for the sole use of the intended recipient(s) and may contain confidential
and privileged information. Any unauthorized review, use, disclosure or
distribution is prohibited. If you are not the intended recipient and
received this in error, please contact the sender by reply e-mail. You are
hereby notified that the copying, use or distribution of any information or
materials transmitted in or with this message is strictly prohibited.
I am working on the intermediate step of coverting from 803.305 to 8.03.4xx before testing the new conversion tool to 9. In the instructions the steps to convert the database are kinda confusing. It says I need to truncate the bi (before image) before restoring it to the new server. My concern is that it will damage the live database. Am I correct in this plan?
run "proutil mfgsys -C truncate bi" on the existing server (do I need to stop all app servers?)
It should be easy to make a backup copy of the production db, then truncate the copy.
I copied our live database to the Pilot database and then ran the truncate function which appeared to run fine (no errors). I then used ProBkUp to backup the Pilot database. I copied it to the new server 8.03.4xx mfgsys database. When I try to use ProRest to restore it there I get the following error:
This backup of a 32-bit DBKEY database contains BI to TL data. It cannot be restored by the 64-bit DBKEY codebase (13732) Use the 10.1A prorest utility to restore the database.
The new server is server 2008 32-bit so I am not sure where the 64-bit reference is coming from. I thought I would be able to restore it there and then run the schema change. What am I missing?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@...> wrote:
_____________________________________________________________________________________________________
[http://www.rapat.com/download/logoflat.jpg%5d<http://www.rapat.com>
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient and received this in error, please contact the sender by reply e-mail. You are hereby notified that the copying, use or distribution of any information or materials transmitted in or with this message is strictly prohibited.
I deleted everything in the db directory and still get the same error. One other strange thing I ran into is when I try to run the Progress Explorer tool I get an error that the mmc has stopped responding.
Sometimes this happens when moving from one location to another if there are already files in the new directory.
You can delete (or move) any files that were in that directory & try preorest again.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Mark Tellefson <mtellefson@...<mailto:mtellefson@...>> wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
On the old server I ran "prostrct repair mfgsys" in the epicor\Pilot803\db directory
Ran probkup in the Pilot803 directory (created PilotBkup.1 that is about 3G)
Copied PilotBkup.1 to the epicor\mfgsys803\db directory on new server
Received the same error as posted before.
I also tried copying the LiveBkup.1 file that was created as part of last night's backup using the same process and got same result.
And, why not wait to truncate until you get this backed up and restored over to the new server?
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mark Tellefson <mtellefson@<mailto:mtellefson@>> wrote:
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
Not sure what I did different but I walked back through the steps below again and it appears to be working. Thanks for the help.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mark Tellefson <mtellefson@...<mailto:mtellefson@...<mailto:mtellefson@...%3cmailto:mtellefson@...>>> wrote:
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mark Tellefson <mtellefson@<mailto:mtellefson@>> wrote:
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
Next problem...Running the client on my computer it ran through the copying all the files to my client directory but then errors out saying that the app server didn't respond in time. The AdminService is running. The app servers are running and the database is running. When I try to run the client on the server it says the system needs to be upgraded.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark Tellefson
To: 'vantage@yahoogroups.com<mailto:%27vantage%40yahoogroups.com>'
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mark Tellefson <mtellefson@...<mailto:mtellefson@...<mailto:mtellefson@...%3cmailto:mtellefson@...<mailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...>>>> wrote:
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Mark Tellefson <mtellefson@<mailto:mtellefson@>> wrote:
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of cooner_55421
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
client.
server.
Ned
Mark Tellefson
Server
Mark Tellefson
Server
Of Mark Tellefson
Server
ahoogroups.com>
To:
ahoogroups.com>
to the new server?
--- In
> From:
> To:
> Server
preorest again.
> --- In
following error:
> > From:
> > To:
> > Virtual Server
truncate the copy.
> > --- In
prohibited.
I ran the schema change per instructions and applied the latest patches. What other conversions would need to be run?
Sent from my iPhone
On Oct 12, 2011, at 5:24 PM, "Ned" <TechnoBabbly@...<mailto:TechnoBabbly@...>> wrote:
client.
server.
Ned
From: <mailto:vantage%40yahoogroups.com> vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:<mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>] On Behalf Of
Mark Tellefson
To: '<mailto:%27vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>'
Server
Mark Tellefson
Server
From: <mailto:vantage%40yahoogroups.com> vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage%40yahoogroups.com>
[mailto:<mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
Of Mark Tellefson
To: '<mailto:%27vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:%27vantage%40yahoogroups.com>'
Server
<mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40y
[mailto:<mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:van
To:
to the new server?
--- In
ahoogroups.com<http://ahoogroups.com>><mailto:vantage%40yahoogroups.com>, Mark Tellefson
> From:
> <mailto:vantage%40yahoogroups.com> vantage@yahoogroups.com<mailto:vantage@yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vanta
> To:
> Server
preorest again.
> --- In
ahoogroups.com<http://ahoogroups.com>><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogrou
ps.com<http://ps.com>>, Mark Tellefson <mtellefson@<mailto:mtellefson@>> wrote:
following error:
> > From:
> > To:
> > Virtual Server
truncate the copy.
> > <http://www.progresstalk.com/showthread.php?114471-truncating-BI> http://www.progresstalk.com/showthread.php?114471-truncating-BI
> > --- In
ps.com<http://ps.com>><mailto:vantage%40yahoogroups.com>, "Mark" <mtellefson@> wrote:
> > [<http://www.rapat.com/download/logoflat.jpg>http://www.rapat.com/download/logoflat.jpg%5d<<http://www.rapat.com>http://www.rapat.com>
> > www.rapat.com<http://www.rapat.com><<http://www.rapat.com>http://www.rapat.com>
prohibited.
<http://groups.yahoo.com/group/vantage/files/.>http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/messages>http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/linksYahoo>http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Mark Tellefson
To: <vantage@yahoogroups.com>
Server
Sent from my iPhone
client.
server.
Ned
tage@yahoogroups.com>] On Behalf Of Mark Tellefson
To:
@yahoogroups.com>'
Server
To:
@yahoogroups.com>'
Server
oogroups.com>
tage@yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Mark
Tellefson
To:
Server
To:
to the new server?
--- In
Mark Tellefson
> One
> From:
> To:
> Server
> there
preorest again.
> --- In
following error:
> > cannot
> > 64-bit
> > From:
> > To:
> > Virtual Server
truncate the copy.
> > --- In
> > .rapat.com>
> > attachments,
prohibited.
/vantage/files/.
p/vantage/messages
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ned
Mark Tellefson
To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Server
Sent from my iPhone
<TechnoBabbly@...<mailto:TechnoBabbly%40gmail.com><mailto:TechnoBabbly@...<mailto:TechnoBabbly%40gmail.com>>> wrote:
client.
server.
Ned
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
tage@yahoogroups.com<mailto:tage%40yahoogroups.com>>] On Behalf Of Mark Tellefson
To:
@yahoogroups.com>'
Server
To:
@yahoogroups.com>'
Server
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>><mailto:vantage%40yah
oogroups.com>
tage@yahoogroups.com<mailto:tage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com>] On Behalf Of Mark
Tellefson
To:
Server
<mailto:vantage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage@yah
tage@yahoogroups.com<mailto:tage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com><mailto:van
To:
to the new server?
--- In
Mark Tellefson
.%3cmailto:mtellefson@...<mailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellef%0bson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@...%3cmailto:mtellefson@..%0b.%3cmailto:mtellefson@...>>>>> wrote:
> One
> From:
<mailto:vanta%20%0b>> ge%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> to:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com><mail
> To:
> Server
> there
preorest again.
> --- In
following error:
> > cannot
> > 64-bit
> > From:
<mailto:van%20%0b>> > tage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:van
<mailto:van%0b>> > tage%40yahoogroups.com>
> > ilto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>><mailto:vantage%40yahoogroups.com><ma
> > To:
> > Virtual Server
truncate the copy.
> > --- In
> > .rapat.com>
> > attachments,
prohibited.
<http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>>http://groups.yahoo.com/group
/vantage/files/.
p/vantage/messages
