Reinstalled w/o the Unicode and everything is working correctly.
I thank you everyone who gave suggestions. Y'all have been excellent and professional to work with.
Heavy kudos to Ned and Jose.
I am now running the UOM DB conversion right now with 22 processors/55Gb RAM. Hopefully this will run a whole lot quicker. Especially when it gets to the parttran table.
William R. King
IT Analyst
Topura America Fastener, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ned
Sent: Thursday, August 01, 2013 9:18 AM
Subject: RE: [Vantage] RE: Connecting to PET on 64bit server.
Manually restore your schema holder to the most recent version in the
mfgsys803\db\backup folder.
That's why your appserver isn't starting nor being able to run the admin
tools.
Also, make sure the DB compatibility mode is set to 9.0(2005) in MS SQL, I
know the only version technically certified to run on SQL 2012 is 9.05.702,
and that is only SQL 2012, not Server 2012.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
William King
Sent: Thursday, August 01, 2013 9:48 AM
Thanks for your patience and assistance.
Completely reinstalled Vantage 8.03.409C with the AdminService10.1B service
only started.
I am also getting the Unable to connect to the AppServer. I check the PET
and everything is started. Then after a timeout period the mfgsys803 changes
to "Still starting, try again later". Then it changes to Not running.
Again my end goal is to get the Data Conversion server with both 8.03.409C
and 9.05.702A on the same server. When I attempt to run the 8.03 Admin Tool
I get "**CRC for VntgVer does not match CRC in SqlVer.p. Try Recompiling.".
I am running SQL Server 2012 on this Data Conversion Server.
I have an EPICOR service call in for this, but would like to shoot this the
user groups way.
Again thanks for your assistance.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Ned
Sent: Tuesday, July 30, 2013 7:10 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Just set them both to manual, and start the one you are going to actively
use at the moment.
Not showing the appserver usually is because of a corrupted
ubroker.properties folder. You may just need to re-install 8.03 to fix that,
or do a complete re-install to fix it, unless you have a backup of the
properties folder from before you installed 8.03 or from afterwards before
it was possibly corrupted.
Making sure no other versions of OE running when you install it is key.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
Of William King
Sent: Tuesday, July 30, 2013 3:31 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Eureka,
Thank you Ned and Jose, that is what the problem is.
Do you suggest me to reinstall Vantage now that the correct OE Admin service
running.
The reason I bring this up is because the PET (yeah, now I have visibility)
does not show the AppServer folder. If this is another question I can start
another thread.
Of Ned
Sent: Tuesday, July 30, 2013 2:01 PM
Check your Task Manager.
Jose got you the reg fix to run it locally, which would have been my
suggestion.
Now here is one more, you mention that you put the 8.03 and the 9.05 with
the DUU on it?
Do you have both Admin Services running on that machine? Meaning both the
10.1B and the 10.2A?
If you do, that's your problem, you can only have one running at a time
without doing a couple more registry tweaks. They both use the same port and
cancel one another out if you have them both runningand you can't connect to
either.
Turn off both admin services, make sure you have no java.exe or any other
OpenEdge related processes running, then start up ONLY the OpenEdge for the
8.03.x version, then try to connect.
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40y
ahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:van
tage%40yahoogroups.com>] On Behalf Of William King
Sent: Tuesday, July 30, 2013 2:37 PM
To:
ahoogroups.com>
Valid question, Yes it is running and startup type is automatic.
ahoogroups.com>
tage%40yahoogroups.com>] On Behalf Of Jose Gomez
Sent: Tuesday, July 30, 2013 1:20 PM
To: Vantage
Subject: Re: [Vantage] RE: Connecting to PET on 64bit server.
You are getting that Error Locally?
Silly Question... is the Admin Service Running?
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E:
jose@...<mailto:jose%40josecgomez.com><mailto:jose%40josecgomez.com><mailto:jose%40josecgomez.c
om>
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Tue, Jul 30, 2013 at 2:13 PM, William King
<wking@...<mailto:wking%40topuraaf.com><mailto:wking%40topuraaf.com><mailto:wking%40topuraaf.com
ahoogroups.com<mailto:vantage%40y%0bahoogroups.com>> [mailto:
ahoogroups.com<mailto:vantage%40y%0bahoogroups.com>><mailto:
<mailto:%0b<mailto:%0b%3cmailto:%0b>>> > vantage%40yahoogroups.com>
om<mailto:jose%40josecgomez.c%0bom>><mailto:
<mailto:%0b<mailto:%0b%3cmailto:%0b>>> > jose%40josecgomez.com>
<mailto:wking%40topuraaf.com%0b>><mailto:wking%40topuraaf.com
<mailto:wking%40topuraaf.com%0b<mailto:wking%40topuraaf.com%0b%3cmailto:wking%40topuraaf.com%0b>>><mailto:
<mailto:%0b<mailto:%0b%3cmailto:%0b<mailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b>>>> > wking%40topuraaf.com>> wrote:
40broadcrown.co.uk<mailto:mhorton%25%0b40broadcrown.co.uk>><mailto:mhorton%
40broadcrown.co.uk<mailto:mhorton%25%0b40broadcrown.co.uk<mailto:mhorton%25%0b40broadcrown.co.uk%3cmailto:mhorton%25%0b40broadcrown.co.uk>>><mailto:
<mailto:%0b<mailto:%0b%3cmailto:%0b<mailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b>>>> > mhorton%40broadcrown.co.uk>
<mailto:%0b<mailto:%0b%3cmailto:%0b>>> > vantage%40yahoogroups.com><mailto:v
<mailto:v%0b<mailto:v%0b%3cmailto:v%0b<mailto:v%0b%3cmailto:v%0b%3cmailto:v%0b%3cmailto:v%0b>>>> > > > > antage%40yahoogroups.com>
<mailto:%0b<mailto:%0b%3cmailto:%0b<mailto:%0b%3cmailto:%0b%3cmailto:%0b<mai
lto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b<mailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmai%0blto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b>>>>>
<mailto:%0b<mailto:%0b%3cmailto:%0b>>> > vantage%40yahoogroups.com><mailto:vantage%40y
<mailto:vantage%40y%0b<mailto:vantage%40y%0b%3cmailto:vantage%40y%0b<mailto:vantage%40y%0b%3cmailto:vantage%40y%0b%3cmailto:vantage%40y%0b%3cmailto:vantage%40y%0b>>>> >
<mailto:%0b<mailto:%0b%3cmailto:%0b<mailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b>>>> > <mailto:%0b>> > >
vantage%40yahoogroups.com> <mailto:
<mailto:%0b<mailto:%0b%3cmailto:%0b<mailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b>>>> > vantage%40yahoogroups.com>
vantage/files/><http://groups.yahoo
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/
vantage/files/>
vantage/files/>
vantage/files/>
William R. King
IT Analyst
tools.
William King
only started.
user groups way.
use at the moment.
Of William King
Eureka,
running.
another thread.
Of Ned
suggestion.
the DUU on it?
either.
ahoogroups.com>
To:
ahoogroups.com>
ahoogroups.com>
To: Vantage
*Jose C Gomez*
*Software Engineer*
E:
om>
> **<wking@...<mailto:wking%40topuraaf.com><mailto:wking%40topuraaf.com><mailto:wking%40topuraaf.com
> Jose - I am now able to run the PET locally on the computer. Thanks
> I am still getting the "Unable to connect to Admin Server. Ensure
> Admin Server is running (8336)."
> From:
> to:vantage%40yahoogroups.com>] On Behalf Of Jose Gomez
> Sent: Tuesday, July 30, 2013 11:58 AM
> To: Vantage
> Change the Following in your 64bit install to get PET to work
> Add this jazz to the registry:
> HKEY_CURRENT_USER\Software\Microsoft\Java VM -> EnableJIT change from
> 01000000 to 00000000
> *Jose C Gomez*
> *Software Engineer*
> E:
> omez.com>
> On Tue, Jul 30, 2013 at 12:48 PM, William King
>awaiting reply.
> > Ned - When I run the PET locally. I get a MMC error stating
> > "Microsoft Management Console has stopped working" I was thinking
> > that I receiving this error because the OS is 64 bit. The same error
> > persist when I run as Admin. I am doing this based of your post on
> > "Database Conversion" put an install of 8.03.410 and 9.05 with the
> > DUU on a box with a bunch of RAM and a couple SSD drives." I don't
> > have 8.03.410 as initial DB (it is 8.03.409C) nor SSDs (using VM)
> > but I can throw a lot of RAM to existing 9.05.702A test installation
> > I am using for Data Conversion. I just need to get the 8.03.409C
> > installation working. I have a call into EPICOR tech support and
> > just
> > Thanks for your help.
> > From:
> > On Behalf Of Ned
> > Sent: Tuesday, July 30, 2013 10:59 AM
> > To:
> > Are you getting any kind of error message?
> > Are you using a local use or a network user to connect? Don't use
> > the Administrator as the name, because if your network and local
> > admin have different passwords, that can often cause confusion.
> > Make sure the user you are trying to connect with is an
> > Administrator on the server you are trying to connect to.
> > Although, why aren't you just using the local version of the PET?
> > You aren't on 9.05 so the version of OpenEdge you are using installs
> > the PET to that 64-bit server because you are still using the 32-bit
> > version of OpenEdge.
> > From:
> > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:van<mailto:van%0b>> > tage%40yahoogroups.com>] On Behalf Of William King
> > Sent: Tuesday, July 30, 2013 11:39 AM<mailto:van%0b>> > tage%40yahoogroups.com>
> > To:
> > Subject: RE: [Vantage] RE: Connecting to PET on 64bit server.vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40y
> > Jose - Firewalls are off on both Servers.
> > Martin - Both server are now at same OE patch level. (found by
> > Version Info). Problem persist.
> > Calvin - Tried the IP address directly (Problem persist).
> > Trying to get Epicor document 10699MPS but can't find on EPICweb.
> > Trying to get from EPICOR rep now. If have it, I'd be interested in
> > having the documentation.
> > From:
> > vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:van<mailto:van%0b>> > tage%40yahoogroups.com>] On Behalf Of Martin Horton
> > Sent: Tuesday, July 30, 2013 9:22 AM<mailto:van%0b>> > tage%40yahoogroups.com>
> > To:
> > Are both 32 and 64 bit servers at the same patch level? I saw
> > something on the progress website that that could cause issues in
> connectivity.
> > Martin Horton
> > Business Systems Manager
> > direct line: +44(0)1889 272250 mobile: +44 (0)7929 059038
> > From:
> ><mailto:
> > Sent: 30 July 2013 15:08
> > To: Vantage
> > Have you tried turing off the Windows FireWall Completely?
> > *Jose C Gomez*
> > *Software Engineer*
> > E:
> > On Tue, Jul 30, 2013 at 10:05 AM, William King
> ><mailto:v%0b>> > > antage%40yahoogroups.com
> > > Sorry, for all the confusion but when you start with 32 bit this
> > > and
> > > 64 bit that, it gets hard explain by text.
> > > I am trying to get to the 8.03.409C (OE PET) on a 64 bit server
> > > from a 8.03.409C (OE PET) on a 32 bit computer.
> > > From:
> ><mailto:<mailto:%0b<mailto:%0b%3cmailto:%0b<mailto:%0b%3cmailto:%0b%3cmailto:%0b%3cmailto:%0b>>>> > vantage%40yahoogroups.com>
> > >ailto:vantage%40yahoogroups.com <mailto:vantage%40yahoogroups.com>]
> > > Sent: Tuesday, July 30, 2013 8:23 AM
> > > To: Vantage
> > > I just re-read your original question you are trying to connnect
> > > Progress Explorer tool for 10.1C to a 10.2A it may not be compatible.
> > > PET doesn't even come with the new version of Open Edge.. Have you
> > > tried installed Open Edge Explorer?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E:
> > > On Tue, Jul 30, 2013 at 9:14 AM, William King
> > > > Jose C Gomez - I just started an EPICOR call Martin Horton -
> > > > IPv6 was already disabled. This has caused me problems elsewhere
> > > > in my
> > network.
> > > > Joshua Giese - Environment below.
> > > > Environment
> > > > TAF2K8DATACONV
> > > > Windows 2008 R2 SP1 (Enterprise) 64-bit 12GB RAM EPICOR
> > > > 9.05.702A (OE
> > > > 10.2a) 32-bit EPICOR 8.03.409C (OE 10.1b) 32-bit SQL 2012 SP1
> > > > 64-bit
> > > > Server to connect
> > > > TAF2K3TEST1
> > > > Windows 2003 SP2 (Standard) 32-bit 4GB RAM EPICOR 8.03.409C (OE
> > > > 10.1b) 32-bit
> > > > From:
> > > > Sent: Tuesday, July 30, 2013 6:38 AM
> > > > To: Vantage
> > > > Have you tried opening an epicor call? They are ususally pretty
> > > > good when ti comes to conversions and such
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E:
> ><mhorton@...<mailto:mhorton%40broadcrown.co.uk><mailto:mhorton%40broadcrown.co.uk><mailto:mhorton%
> > > > <http://www.josecgomez.com/feed/> <http://www.usdoingstuff.com>
> > > > On Tue, Jul 30, 2013 at 3:23 AM, Martin Horton
> > > > >wrote:
> > > > > I might be dreaming this, but I seem to recall ipv6 causing an
> > > > > issue if it was active on the server (ours wasn't configured
> > > > > so that may make the difference).
> > > > > Martin Horton
> > > > > From:
> > > > > om
> > > > > Sent: 29 July 2013 20:58
> > > > > To:
> > > > > Subject: [Vantage] RE: Connecting to PET on 64bit server.
> > > > > Thank you for your information.
> > > > > Does anyone else have any more ideas?
> > > > > William R. King
> > > > > IT Analyst
> > > > > From:
> > > [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40y
> > > > > antage%40yahoogroups.com>] On Behalf Of Joshua Giesevantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40y
> > > > > Sent: Monday, July 29, 2013 11:32 AM
> > > > > To:
> > > > > antage%40yahoogroups.com>vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40y
> > > > > Great! At least you know there isn't a firewall issue and that
> > > > > the service is running.
> > > > > Joshua Giese
> > > > > CTO
> > > > > 920.437.6400 Ext. 337
> > > > > Site ID: 27450-E905700B2-SQL64
> > > > > From:
> ><mailto:
> > > > > Sent: Monday, July 29, 2013 10:05 AM
> > > > > To:
> > > > > Joshua thank you for your response.
> > > > > The telnet shows the blinking cursor.
> > > > > William R. King
> > > > > IT Analyst
> > > > > From:
> > vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > > >m
> > > > ><mailto:
> > > > > Sent: Monday, July 29, 2013 9:55 AM
> > > > > To:
> > > > > Subject: RE: [Vantage] Connecting to PET on 64bit server.
> > > > > What port do you have your admin service setup on? You could
> > > > > as a simple test try to telnet to the remote address and port
> > > > > and if you get the blinking dash you have an open port with a
> > > > > service listening on the other end but something else is wrong.
> > > > > It's a good first line of defense quick check at least. I've
> > > > > had situations where the port and service are listening but I
> > > > > still get that error due to other
> > > > reasons.
> > > > > Joshua Giese
> > > > > CTO
> > > > > From:
> > > > > om
> > > > <mailto:
> > > > > Sent: Monday, July 29, 2013 9:34 AM
> > > > > To:
> > > > > Subject: [Vantage] Connecting to PET on 64bit server.
> > > > > I am configuring an Data Conversion Server for 8.03.409C to
> > > > > EPICOR 9.05.702A as per last week's thread on Database conversion.
> > > > > I attempting to get to the PET on the 64bit Server by going to
> > > > > our existing 32bit Test Vantage 8.03.409C installation. These
> > > > > are the steps I am following.
> > > > > 1. Open the PET on the 32bit Test Vantage 8.03.409C installation.
> > > > > 2. R-Click the Progress Explorer
> > > > > 3. Add Progress Server
> > > > > 4. Enter the Server name for the 64bit 9.05 Conversion Server
> > > > > 5. Select OK
> > > > > 6. R-click connect the newly added 64bit 9.05 Conversion Server.
> > > > > 7. Select OK (authentication information is correct)
> > > > > 8. Then I get the error " Unable to connect to Admin Server.
> > > > > Ensure Admin Server is running (8336).
> > > > > Firewall is off on both servers.
> > > > > AdminService10.1B service is running on the 64bit 9.05
> > > > > Conversion
> > > Server.
> > > > > #netstat -an on the 64bit 9.05 Conversion Server shows that
> > > > > port
> > > > > 20931 is listening.
> > > > > Any help would be appreciated.
> > > > > William R. King
> > > > > IT Analyst
> > > > > Broadcrown Ltd. Airfield Industrial Estate, Hixon, Stafford,
> > > > > Staffs
> > > > > ST18 0PF, England
> > > > > tel: +44(0)1889 272200 fax: +44(0)1889 272220
> > > > > www.broadcrown.com<http://www.broadcrown.com>
> > > > > ----- This email and the information it contains is
> > > > > confidential and may be legally privileged. It may be read,
> > > > > copied and used only by the intended recipient. Internet
> > > > > communications cannot be guaranteed to be secure or indeed
> > > > > error free as information can be intercepted, corrupted, lost,
> > > > > destroyed, delayed and or contain
> > viruses.
> > > > > Broadcrown Ltd has scanned the email for viruses but does not
> > > > > accept responsibility once the email has been transmitted. The
> > > > > receiving company should scan the email and attachments (if
> > > > > any) for
> > viruses.
> > > > > Any views or opinions expressed within this email are not
> > > > > necessarily the views or opinions of Broadcrown Limited except
> > > > > where the sender specifically states that they are. If you
> > > > > have received this document in error please email the sender
> > > > > and delete the message from your computer without taking
> > > > > copies
> > > > must have already linked your email address to a yahoo id to
> > > > enable
> > access.
> > > > Builder and Crystal Reports and other 'goodies', please goto:
> > > enable
> access.
> > > com/group/vantage/files/><access.
> > m/
> > must have already linked your email address to a yahoo id to enable
> > )access.
> > vantage/files/>
> > )[Non-text portions of this message have been removed]
> have already linked your email address to a yahoo id to enable access.
vantage/files/>
vantage/files/>
vantage/files/>
