Copy customization from PO Entry to PO Tracker?
I’ve spent a fair amount of time creating/designing a new sheet (that uses a BAQ Data View) that I docked to the PO Release form in Purchase Order Entry.
I would like to duplicate what I’ve created and add the same customization in PO Tracker. Is this possible?
Thanks!
Todd Gilbert
Not without manually doing it through the XML. Depending on what you want to see in tracker you can turn your PO Entry customization into a Tracker view though. But you lose the links to other records that trackers typically give you access to.
