Creating a UD record using Rest
Hi All,
Anyone able to create a ud record using rest?
Ive tried the GetANewUd, the general UD post and the other custom methods but cant seem to get it to work.
I dont want to build the logic inside the ubaq and let the api do it.
Any help would be great
Aaron
Don’t fully discount this. I use this method quite a bit because it’s easier to upgrade in the event that they change the REST signature. You’ll only be making a single REST call to your BAQ instead of multiple REST calls to create the record.
Food for thought.
Otherwise, I just tested this out and it worked fine using the UD10Svc.Update call:
  "ds": {
    "UD10": [
        "Company": "C001",
        "Key1": "Test1",
        "Key2": "Test2",
        "Key3": "",
        "Key4": "",
        "Key5": "",
        "Character01": "Meep",
        "SysRowID": "00000000-0000-0000-0000-000000000000",
        "RowMod": "A"
    "UD10Attch": [],
    "ExtensionTables": []
Note–RowMode being set to “A” is essential to make the add work.
I’m getting this
Sorry! Something went wrong. Please contact your system administrator.
  "ds": {
    "UD02": [
        "Company": "TEAGLE",
        "Key1": "4000",
        "Key2": "6000",
        "WebUserUID_c": "GDPR",
        "CreationDate_c": "2022-12-17:54:12.570Z",
        "Name_c": "GDPR",
        "Email_c":"GDPR",
        "Password_c": "GDPR",
        "Confirmed_c": false,
        "RowMod": "A"
    "UD02Attch": [],
Any ideas?
So I found the problem with the above error… It was my date.
Needs to be format 2022-12-31 now I’ve got another funny issue… I’ve just ran a BAQ on UD02 and no data is being returned but if I use Swagger… bam! Rows… WTF? :rofl:
Ignore me. I had a GetList custom code running hiding processed rows. -.-
Thank you…
All working :smiley:
[quote="aarong, post:5, topic:97865]
[/quote]
Don’t feel bad. I spent over an hour tracking down a very strange bug yesterday only to discover that I’m an idiot at the end. Not only that, I had reused the piece of code lower down, and was an idiot twice.
*nothing to see here
I just love those…
I had one while back… setting a field using a bpm from false to true but automatically setting back to false after. I spent 2 days working that one out… rewrote code multiple times… :rofl:
Luckily this time I only did a lot of /* */ :slight_smile:
Good morning,
I’m trying to use the Rest API to call UD11Svc/Update and post this
  "ds": {
    "UD11": [
        "Company": "T300",
        "Key1": "1689774713881",
        "Key2": "",
        "Key3": "",
        "Key4": "",
        "Key5": "",
        "Character01": [
            "JobNum": "J049340",
            "AsmSeq": 0,
            "OprSeq": 20
            "JobNum": "J049341",
            "AsmSeq": 0,
            "OprSeq": 20
        "RowMod": "A"
    "UD11Attch": [],
I am getting the “Sorry! Something went wrong. Please contact your system administrator.” error message. Does any of the JSON above look incorrect? What might be the issue I can look into?
Check the Event Viewer on your server. It will tell you why it’s complaining.
Pff Maeldan Benenuts GIF - Pff Maeldan Benenuts Sheldon - Discover & Share GIFs
You’re trying to insert an object array into a string field.
Edit:
If you are wanting to store Json in that field:
	"ds": {
		"UD11": [{
			"Company": "T300",
			"Key2": "",
			"Key3": "",
			"Key4": "",
			"Key5": "",
			"Character01": "[{\"JobNum\": \"J049340\",\"AsmSeq\": 0,\"OprSeq\": 20},{\"JobNum\": \"J049341\",\"AsmSeq\": 0,\"OprSeq\": 20}]",
			"RowMod": "A"
		"UD11Attch": [],
@skhan this will do what you were trying to do the other day. This was the post I was trying to find.
