Make a new formula in Crystal Reports.
For this example, let's name the formula "PayeeCAPS"
In the formula, insert the field that is the "Payee" field for the
check. Not sure what it is off the top of my head. Then, use the
UCASE() function to send it to Upper Case. Drag and drop your new
formula on to the report. Remove the old field that is mixed case.
HTH
Of msturm
Sent: Thursday, January 13, 2011 12:42 PM
Subject: [Vantage] Crystal 8.5 Report - Change field to uppercase
I have been tasked with updating our check print report.
I have practically no crystal experience and have made the simple
adjustments; fonts and position changes. They would like the payee to be
in all caps. How should this be done? I'm sure it's a pretty vague
question without seeing the report.
Thanks for helping this report newbie.
HTH
Of msturm
