Crystal calc
If your intent is not to display the field if it equals zero. You might try
to format the field, select the number tab, select customize button, select
suppress if zero.
Hope this is what you were looking for.
Dan Shallbetter
States Electric. Mfg.
Sent: Tuesday, June 25, 2002 1:25 PM
Subject: [Vantage] crystal calc
Hi everyone!
I don't remember how I set up this calculation to work. I want this
calculation to display the "shift pay" if it is greater than 0. Otherwise,
display nothing. This is my calculation so far. I'm not sure how to set it
up so it will not display anything if the case is false.
IIF ({PRChkDtl.ShiftPay} > 0,{PRChkDtl.ShiftPay}, InStr
({PRChkDtl.ShiftPay},'' ))
Thanks!
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
Burton, Michigan
Hi everyone!
I don't remember how I set up this calculation to work. I want this calculation to display the "shift pay" if it is greater than 0. Otherwise, display nothing. This is my calculation so far. I'm not sure how to set it up so it will not display anything if the case is false.
IIF ({PRChkDtl.ShiftPay} > 0,{PRChkDtl.ShiftPay}, InStr ({PRChkDtl.ShiftPay},'' ))
Thanks!
Wendy Bowen
Burton, Michigan
Hi Wendy,
You can't display "nothing" with a number, it will always print a ZERO if there is no value. So to display "nothing", you will have to use strings in your formula.
You could use the Crystal format in a formula like this:
If {PRChkDtl.ShiftPay} > 0 then totext({PRChkDtl.ShiftPay})
else ""
Unfortunately, with converting numbers to strings you lose the ability to easily format decimal places, dollar signs, etc. without a lot of other string manipulations.
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Tuesday, June 25, 2002 11:25 AM
Hi everyone!
Thanks!
Wendy Bowen
Burton, Michigan
