Crystal Forms
Has anyone modified the Crystal standard PO, AR and check forms? Is anyone
willing to share how they modified the forms? I'm trying to reduce the
header in the AR and PO forms so that it doesn't take up a lot of each page.
In the check form, I am trying to have the check info repeat in the 1st
section and 2nd section (we have preprinted 3 part checks).
Thanks for any help.
Kyle Chin
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.13.10/189 - Release Date: 11/30/2005
I am trying to add another database table to a pre-exitsing report....
How do I do this...I get as far as the Data Explorer and I can not
seem to figure out where to go from there....
Any help you can give would be great! Thanks
Hi,
I assume you are adding to a pre-existing Vantage report. Is that true?
And you want to add a field from another table that is not included in the
report?
Troy Funte
Liberty Electronics
Sent: Tuesday, April 01, 2003 1:00 PM
Subject: [Vantage] Crystal Forms
Yahoo! Groups Sponsor
ADVERTISEMENT
yes --- that is correct....
Sent: Wednesday, April 02, 2003 6:39 AM
Subject: RE: [Vantage] Crystal Forms
Hi,
report?
Troy Funte
Liberty Electronics
ADVERTISEMENT
and
ADVERTISEMENT
Cheryl,
What you need to do is use a subreport with Crystal for the additonal
database table.
The subreport will simply contain just the table (connected via ODBC) that
has the field you want to use in your report.
The linking between the main report and the subreport is the tricky part.
All fields in Vantage .dbf files are converted to strings when you run the
report from Vantage. If the key linked field in the subreport is a numeric
filed (for instance, PONum), then you will need to create a formula in the
main report to convert the string to a number. Then you can link the
formula in the main report to the key field in the subreport.
This is the overview. If you need more details, I can try to answer more
specific questions.
Troy Funte
Liberty Electronics
Sent: Wednesday, April 02, 2003 8:24 AM
Hi,
true?
the
report?
Troy Funte
Liberty Electronics
ADVERTISEMENT
and
ADVERTISEMENT
and
ADVERTISEMENT
