Jim, I believe the export length is hard-coded into epicor's DBF export code
in the quote module. However, If you have ODBC, you can probably link to
the full-length field. (we don't use ODBC)
As far as the quote quantities, have you tried limiting the "Can Grow"
option for the extended descriptions?
~Thaddeus
Sent: Monday, October 29, 2001 4:09 PM
To: Vantage@Yahoogroups. Com
Subject: [Vantage] CRYSTAL QUOTE FORM
I am trying to figure out how you can increase the number of characters in a
string field. The salesperson on the quote header is only pulling across 20
characters but if you look at the field on the vantage side it is 30
characters. How can I make these match? Also on the quote form has anyone
figured a way to have the different quote quantities start on line 1 of the
quote with the part number but not be pushed down when you have extended
descriptions for the remaining quantities. Any help would be appreciated. We
are still on 3.00.
Jim Frice
Assistant Controller
William Frick & Company
730 Forest Edge Drive
Vernon Hills, IL 60061
PH: 847-634-6341 EXT. 151
FAX: 847-634-2233
E-Mail: Jim.Frice@...
~Thaddeus
are still on 3.00.
Jim Frice
FAX: 847-634-2233
