It could be the type of Join you used to add the table. There are only Inner/Outer and Left/Right combos so just mess around with the code to see if that resolves it.
Also - be wary of 'automatic' (over)linking that plagues many drag/drop apps like Crystal. Read the WHERE statements to make sure some 'over-exuberant' GUI created field to field link didn't wipe out your ability to draw in the data in the way you need it presented.
Rob Brown
sanfranc415 <sanfranc415@...> wrote:
I just realized that it's not printing any of the assembly information
once I add the OrderHed table. Does this make any sense to anybody?
--SF
Rob Brown
--SF
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> Well, I kinda have it figured out. I removed all relationships in the
> Report Definitions and added just one:
> Parent Table:JobShip
> Key:
> Child Table:OrderHed
> Relationship Field:
> Seq 1, Parent Field Name: OrderNum, Child Field Name: OrderNum
> Seems to work fine, but I still have to select "Shipping Schedule" on
> the "Print Box." If I don't select this box it will print a blank
> page. Anybody know why it prints a blank page if I don't select
> "Shipping Schedule?"
> Thanks,
> --SF
> --- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@> wrote:
> > I'm running 803.403D.
> > --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@> wrote:
> > > You don't say what Vantage version you are on - and this may thus be
> > a dumb question - but are you SURE your linked OrderNum fields are the
> > same (compatible) type.
> > > Similarly, are you SURE CustNum in OrderHead is related to Company
> > in JobShip?
> > > We are on 8.03.403 and my 1st assumption when seeing a column
> > named 'Company' would be that it is YOUR (or our) company data table
> > entity record key - NOT the customer's.
> > > Rob Brown
> > > sanfranc415 <sanfranc415@> wrote:
> > > Well, I've linked the OrderHed.Custnum and
> > OrderHed.ORderNum both to
> > > the JobShip.OrderNum and JObShip.Company, but still it's not
> > > retrieving any data for the OrderHed able.
> > > --SF
> > > --- In vantage@yahoogroups.com, "Ken Williams" <ken@> wrote:
> > > > Check your joins in Crystal under Database/Database Expert. More
> than
> > > > likely there is a relation that's not fully defined or a link that
> > needs
> > > > to be an outer join somewhere.
> > > > Ken
> > > > ________________________________
> > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> > Behalf
> > > > Of sanfranc415
> > > > Sent: Thursday, January 24, 2008 5:09 PM
> > > > To: vantage@yahoogroups.com
> > > > Subject: [Vantage] Crystal Report - Job Traveler
> > > > I'm trying to get this report to display a checkbox
> > > > (Orderhed.Checkbox01) in the OrderHed. I've created a
> relationship in
> > > > the Report Definitions (JobTrav), but each time in Crystal
reports I
> > > > add the OrderHed all the information on the Traveler disappears.
> > > > Thanks,
> > > > --SF
> > > > [Non-text portions of this message have been removed]
> > > Never miss a thing. Make Yahoo your homepage.
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
