Has anyone been able to make an on field change event for a custom grid/dataview?
I am following some code from @josecgomez and @jgiese.wci where I bind a baq data view to a custom grid.
This code is wild because when you add it to the editor it adds a dataview that you can actually bind things to. However, I feel like the on change events are struggling to recognize it or maybe I am doing something blatantly wrong…
baqViewWeights = new BAQDataView("gf-testweight");
oTrans.Add("WeightsForOrder",baqViewWeights);
Now I would like to add some event handlers for field change events on the grid/datat view “WeightsForOrder,” but every time I do that I get errors as seen below.
Here is the change event:
this.WeightsForOrder_Row.EpiRowChanging -= new EpiRowChanging(this.WeightsForOrder_BeforeRowChange);
‘Script’ does not contain a definition for ‘WeightsForOrder_Row’ and no extension method ‘WeightsForOrder_Row’ accepting a first argument of type ‘Script’ could be found (are you missing a using directive or an assembly reference?)
It’s almost as if the form doesn’t know about the dataview.
I’m thinking about making change events for the grid rows themselves, but still my question remains, why can’t I make a change event for the underlying custom BAQ data view?
‘System.Data.DataView’ does not contain a definition for ‘EpiRowChanging’ and no extension method ‘EpiRowChanging’ accepting a first argument of type ‘System.Data.DataView’ could be found (are you missing a using directive or an assembly reference?)
It’s all good Jose, I appreciate you trying to help.
This is a curiosity project I am on to see how I can make a grid that someone can type into on an existing form and then do actions based on the field changing. I wanted to use existing data in the field change logic.
However, I should have first figured out how to make a column editable in the ultraGrid that it is bound to…
When I return the results from the BAQ using code I found(as seen below). The grid is all read only, can I not edit any of it?
I can even go to the collection in the properties tab and change the two fields from REad only = true to read only = false, but the settings don’t stay when I save the customization.
private void RefreshBAQDataView(BAQDataView iBaqView)
MethodInfo mi = iBaqView.GetType().GetMethod(“invokeExecute”, BindingFlags.Instance | BindingFlags.NonPublic);
mi.Invoke(iBaqView, new object{ true });
I have used another epimagic trick of yours in binding a baq result dataset from the dynamic query adapter to a grid which could also work here, but in that demo it isn’t a dataview… where I can do any change event logic.
Nah, I’m so far away from the right path here Jose. Thanks for answering the first change event logic question.
I am trying to get this BAQ to sub to a field on the screen as an execution parameter as well and I haven’t even tried that yet, but I sense it’s going to be a headache.
I appreciate your input here Jose! Again, I’m just playing around with epimagic today trying to solve something I could do with an embedded dashboard.
