Good morning team,
I want to add a custom field on a dashboard that I create, i want to subtract the ´On Hand Qty´ minus ´Reserved Qty´ and display that. Any advice?
Do it in the BAQ as a calculated field.
Oh ok! Just one more thing, how does the minus operation works in the editor?
this field - that field = your new field?
to elaborate, custom fields follow SQL syntax in the BAQ editor.
Go to your help file in the user guides, tool guides, and start reading about BAQ’s. It a really good introduction to get you started on some of the basics.
OK, all done! Thanks everyone.
One more little thing, does anyone know from where the ´Available Qty´ field on the Counter Sales Dtl (in Order Entry) takes the data? I want to add this data to a new dashboard.
That one is a calculated field (not in the database), and doesn’t always work right. There are a few threads about that field being problematic. You’ll probably have to defined what you want “available” to mean for your company and calculate it yourself. It will probably be a subquery and becomes a bit more of a complicated BAQ.
example:
