Hi everyone, am a total noob at Epicor and currently have no available resources for any formal training so reaching out to all the helpful folks out here.
I followed a fellow user’s guide here on creating a customization on a dashboard (video linked all the way down below if you’re curious), but for whatever reason the customization is not showing up on Menu Maintenace - so right now the customization is only accessible on developer mode.
I am having the exact same issue as Fakhruddin down here below. On the same version too (10.2.600.3). They did say the fix ended up being “updating the menu table using updatable BAQ”, but I am not so sure what the steps are for this, and googling can only help me so much. Can someone please walk me through this process? Or at least explain a bit more in detail what this means.
Make sure Work In Progress checkbox is not checked on the customization in customization maintenance. Also if you had the menu form open you may need to right click in the Customization dropdown and select “Refresh List”
Strange. Did you try closing and reopening the client? Beyond that, if your menu item is company specific I’d try saving it with the company the menu item is in
