Customization - how do I set a tab visibile if user is a member
Thanks for the quick reply Joe and Jose - both answers helped out so my code is now compiled.
Tim Lester
Hi,
I have a customization that will set a tab to visible = false on load. However, I want the tab visible to certain groups. How do I set it after they enter a part for example? I have tried to use the after update and after exit edit mode, so far no success (just for a message box). The customization will be for Part Entry.
TIA,
Karen
Check out this example from Jose. Same idea but instead of disabling a button, hide the tab.
http://www.usdoingstuff.com/2012/01/24/epicor-9-group-button-security/
Sent: Tuesday, December 11, 2012 10:45 AM
Subject: [Vantage] Customization - how do I set a tab visibile if user is a member of a group?
Hi,
TIA,
Karen
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Thanks for the quick response Ted (and indirectly Jose :) ). I will see what I can do with this!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Sent: Tuesday, December 11, 2012 10:42 AM
Subject: Re: [Vantage] Customization - how do I set a tab visibile if user is a member of a group?
From: Karen Schoenung <kschoenung@...<mailto:kschoenung%40fisher-barton.com>>
Hi,
TIA,
Karen
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
So, I am not sure what I am doing wrong, but I am always getting the tab visible...My code compiles without error, but something is incorrect in the logic. I am testing with one user who is a member of the group and one who is not...The BAQ shows only one row (user who is a member). I have the control property set visible to false. Any ideas? Code is below...
Sub InitializeCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
'// Begin Wizard Added Variable Intialization
'// End Wizard Added Variable Intialization
'// Begin Custom Method Calls
'// End Custom Method Calls
Dim Chemistry as EpiBasePanel = CType(csm.GetNativeControlReference("b7ef62fe-8b9b-454d-b24e-85e4b10c5a37"),EpiBasePanel)
Dim _dq As New DynamicQuery(DirectCast(oTrans.Session, Session).ConnectionPool)
Dim ds As DataSet = _dq.ExecuteByID("TST-SecAdvTest")
Dim found As Boolean = False
For Each dr As DataRow In ds.Tables(0).Rows
If dr("UserFile.DcdUserID").ToString().ToUpper().Equals(DirectCast(oTrans.Session, Session).UserID.ToUpper()) Then
found = True
End If
Next
Chemistry.Visible = found
End Sub
Hi,
TIA,
Karen
Karen,
Sometimes the Epicor logic will flip a Tab to Visible. Where are you trying
to do this? And which tab
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Tue, Dec 11, 2012 at 2:46 PM, Karen Schoenung <
> If
> found = True
> End If
> Next
> End Sub
> Of Ted Koch
> Hi,
> TIA,
> Karen
In Part Entry, a custom tab we made (new tab between Comments and Dimensions)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Tuesday, December 11, 2012 1:54 PM
To: Vantage
Karen,
Sometimes the Epicor logic will flip a Tab to Visible. Where are you trying to do this? And which tab
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Variable Intialization' lines ** '// Begin Wizard Added Variable
> Intialization
> '// End Wizard Added Variable Intialization '// Begin Custom Method
> Calls
> a37"),EpiBasePanel) Dim _dq As New
> Dim ds As DataSet = _dq.ExecuteByID("TST-SecAdvTest") Dim found As
> Boolean = False For Each dr As DataRow In ds.Tables(0).Rows If
> .Session,
> found = True
> End If
> Next
> End Sub
> Behalf Of Ted Koch
> Hi,
> TIA,
> Karen
Oh a Custom Tab. That should work fine.. Hmmm
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Dec 11, 2012 at 3:00 PM, Karen Schoenung <
> Dimensions)
> Of Jose Gomez
> To: Vantage
> Karen,
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> Code is below...
> > Intialization
> > Calls
> > .Session,
> > found = True
> > End If
> > Next
> > End Sub
> > Behalf Of Ted Koch
> > Hi,
> > TIA,
> > Karen
I think I got it now...I moved the code to the form load event instead of initializeCustomCode. More testing to verify :)
Sent: Tuesday, December 11, 2012 2:05 PM
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Dimensions)
> To: Vantage
> Karen,
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> Code is below...
> > Added Variable Intialization' lines ** '// Begin Wizard Added
> > Calls
> > c5
> > ns
> > .Session,
> > found = True
> > End If
> > Next
> > End Sub
> > Behalf Of Ted Koch
> > y/
> > Hi,
> > TIA,
> > Karen
I am working on something similar to this but Enable/Disable a ComboBox on a form. The link to usdoingstuff webpage is broken but I found the YouTube video and followed along - I am close but getting a reference error and hoping someone knows where the problem is.
First error is: The type or namespace name 'Datarow' could not be found (are you missing a using directive or an assembly reference?) and second error is: 'dr' is a 'variable' but is used like a 'method'
Not sure if Jose's YouTube video left out a reference and it was listed on the webpage - any suggestions would be helpful.
Thanks.
Tim Lester
It should be DataRow (its case sensitive)
Jose C Gomez
Software Engineer
On Thu, Dec 11, 2014 at 10:32 AM, tlester@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>I am working on something similar to this but Enable/Disable a ComboBox on a form. The link to usdoingstuff webpage is broken but I found the YouTube video and followed along - I am close but getting a reference error and hoping someone knows where the problem is.</p><div><br></div><div>First error is:Â The type or namespace name &#39;Datarow&#39; could not be found (are you missing a using directive or an assembly reference?) and second error is: &#39;dr&#39; is a &#39;variable&#39; but is used like a &#39;method&#39;</div><div><br></div><div>Not sure if Jose&#39;s YouTube video left out a reference and it was listed on the webpage - any suggestions would be helpful.</div><div><br></div><div>Thanks.</div><div><br></div><div>Tim Lester</div><div>Â </div><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
Jose - thanks, guess I did not look close enough at the case.
Here is the last error:
 Error: CS0118 - line 61 (654) - 'dr' is a 'variable' but is used like a 'method'
Here is the code portion with the error:
foreach(DataRow dr in ds.Tables[0].Rows)
if(dr("UserFile.DcdUserID").ToString().ToUpper().Equals(((Session)oTrans.Session).UserID.ToUpper()))
found=true;
Tim Lester
Should be dr["UserFile.DcdUserID"]
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
addr: 37 Shuman Ave | Stoughton | Ma | 02072-3734
jrojas@... | www.matsinc.com
Ask us about our clean, green and beautiful matting and flooring
[cid:21de0a.png@393d745a.4e9a2d38]
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Sent: Thursday, December 11, 2014 10:43 AM
Subject: Re: [Vantage] Re: Customization - how do I set a tab visibile if user is a member of a group?
found=true;
Tim Lester
