My text box solution may be it then...
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Late, Travis
Sent: Tuesday, June 09, 2009 1:46 PM
Subject: RE: [Vantage] Re: Customization MES Screen
That did not seem to work. I just added a barcode for backspace for the
time being, but I'll have to get some solution eventually.
Behalf
Of Rob Bucek
Sent: Tuesday, June 09, 2009 12:50 PM
If that works I wish I would have known about that when I started out!
That seems a whole lot easier..
Rob Bucek
FAX: 715-284-4084
<http://www.dsmfg.com/ <http://www.dsmfg.com/> >
Behalf
Of Michael McWilliams
Sent: Tuesday, June 09, 2009 12:39 PM
Subject: [Vantage] Re: Customization MES Screen
in the client config folder, open the default.mfgsys then change
<SelectTextOnEnter value="False" bool="" />
to
<SelectTextOnEnter value="True" bool="" />
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
Behalf
Rob Bucek
FAX: 715-284-4084
Of Late, Travis
Behalf
Of Rob Bucek
Rob Bucek
FAX: 715-284-4084
Behalf
to
> Where do I find this?
Behalf
> Of Sean McDaniel<mailto:vantage%40yahoogroups.com>
> Sent: Tuesday, June 09, 2009 12:06 PM
> Subject: RE: [Vantage] Customization MES Screen<mailto:vantage%40yahoogroups.com>
> In the configuration file you have the ability to select the entire
> field by
> default.
> Go in and change this instead - will make your life MUCH easier.
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Behalf Of<mailto:vantage%40yahoogroups.com>
> Rob Bucek
> Sent: Tuesday, June 09, 2009 12:49 PM
> Subject: RE: [Vantage] Customization MES Screen<http://www.dsmfg.com/> > >
> To date, what method(s) have you used to remove the zero? I assume you
> are speaking of the fields that the operator enters the assembly and
> operation they intend to work on? Just curious, what are you trying to
> accomplish by doing that? I only ask because there may be other
> solutions depending on what you are trying to accomplish.
> Rob Bucek
> FAX: 715-284-4084
> <http://www.dsmfg.com/ <http://www.dsmfg.com/> <http://www.dsmfg.com/
> <mailto:vantage%40yahoogroups.com> ] On<mailto:vantage%40yahoogroups.com>
> Behalf
> Of Late, Travis
> Sent: Tuesday, June 09, 2009 10:40 AM
> <mailto:vantage%40yahoogroups.com>in
> Subject: [Vantage] Customization MES Screen
> I'm trying to customize a customization that I currently have set up
> MES. I have a customization on Start Production Activity that showsthe
> Qty Remaining and Qty Completed. What I want to do seems very simple,this
> but it won't save.
> I want to be able to take out the 0 by the Assembly and the Operation.
> There is a 0 in both of these fields. When I go into take out the 0
> through customization and save it just puts the 0 back in. I'm sure
> is a simple fix. If anyone has any suggestions let me know what I'm[Non-text portions of this message have been removed]
> missing.
> Thanks,
> Travis Late
> ERP Project Manager
> M-B Companies, Inc
> 1200 Park Street
> Chilton, WI 53014
> Phone: 920-898-1560 Ext.152
> Cell: 920-960-0062
> Email: tlate@... <mailto:tlate%40m-bco.com>
> <mailto:tlate%40m-bco.com> <mailto:
> tlate@... <mailto:tlate%40m-bco.com> <mailto:tlate%40m-bco.com>
> <mailto:tlate%40m-bco.com> >
