Customization To The Job Schedule Form
Yup... it was one of those weird ones... that solved my problem...
Thank you!!!
Marco Vissuet
Systems Engineer
Pacific Contours Corporation
Cell (619)507-2311
Anaheim Office (714) 693-1260
San Diego Office (619)670-3900
Fax (714) 693-1252
mvissuet@...<mailto:marcov@...>
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties. Disseminate in accordance with provisions of DoD Directive 5230.25.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Sent: Wednesday, June 19, 2013 9:12 AM
Subject: Re: [Vantage] Customization To The Job Schedule Form
I think this is a weird one where you need to name the customization for the Job Scheduling form exactly the same name as the customization for job entry, I would try that.
From: Marco Vissuet <mvissuet@...<mailto:mvissuet%40pacificcontours.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Wednesday, June 19, 2013 12:05 PM
Subject: RE: [Vantage] Customization To The Job Schedule Form
I meant the Job Scheduling Form,
From job entry, click on actions, schedule, Job Scheduling...
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
mvissuet@...<mailto:mvissuet%40pacificcontours.com><mailto:marcov@...<mailto:marcov%40pacificcontours.com>>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Ted Koch
Sent: Wednesday, June 19, 2013 8:16 AM
I'm assuming you mean the Job Scheduling Board? Use Menu Maintenance?
From: supertico05 <mvissuet@...<mailto:mvissuet%40pacificcontours.com><mailto:mvissuet%40pacificcontours.com>>
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Sent: Wednesday, June 19, 2013 10:36 AM
Subject: [Vantage] Customization To The Job Schedule Form
I made a customization to the job schedule form, but I can't figure out how to set up the process on how to launch it as the default.
When I open the form through customization the window that pops up telling you what process it's running does not pop up.
Does anybody know how to set the default for this form?
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
If you are running the Job Scheduling Board from the Scheduling/General Operations menu simply update the menu item.
If you are running the customization from Job Entry/Actions/Schedule you will need to follow these procedures. All these options are under System Management/Utilities:
1. In Menu Maintenance create a new Process.
a) Menu ID: UD<whatever you want to call it>
b) Module: XA
c) Name: <whatever you want>
d) Security: Pick security ID (perhaps that of Job Scheduling Board?)
e) Order Sequence: Any number not in use by those listed in the processes tree.
f) Enabled: Checked
g) Non-Menu Item
h) Icon: Entry
i) Program: Epicor.Mfg.UI.App.JobEntry.ScheduleForm
i) Customization: <your customization>
and Save
2. Create a new Process Calling Maintenance:
a) Called Process Reference: Epicor.Mfg.UI.App.JobEntry.ScheduleForm.dll
b) Called From: <blank>
c) Menu ID: <id you assigned above>
HTH,
Calvin Dekker
[cid:image001.jpg@01CE6CD7.C1C90BF0]<http://www.codabears.com/>
(630) 672-7688 x1484
*Solutions for Epicor users.
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of supertico05
Sent: Wednesday, June 19, 2013 9:36 AM
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
From: supertico05 <mvissuet@...<mailto:mvissuet%40pacificcontours.com>>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Marco Vissuet
Systems Engineer
Cell (619)507-2311
Fax (714) 693-1252
"I think this is a weird one where you need to name the customization for
entry, I would try that."
This should work. We ran into the same thing with customizing Where Used,
which is launched from the Part Maintenance app. We had to create a
WhereUsed Customization that was named the same as the customization on the
However, we've not yet figured out how to make this work when launching
Where Used from Part Tracker.
> From: Marco Vissuet <mvissuet@...>
> Marco Vissuet
> Systems Engineer
> Cell (619)507-2311
> Fax (714) 693-1252
> Of Ted Koch
