Can you send me or post a screen shot of the properties screen for the check box that you are trying to access? Make sure the the epiGUid is visible.
jimki@...
jimki@...
--- In vantage@yahoogroups.com, "k99ja04" <jallmond@...> wrote:
> Here is my complete code.
> '// Custom VB.NET code for ReportForm
> '// Created: 2/18/2010 10:33:34 AM
> Imports System
> Imports System.Data
> Imports System.Diagnostics
> Imports System.Windows.Forms
> Imports System.ComponentModel
> Imports Microsoft.VisualBasic
> Imports Epicor.Mfg.UI
> Imports Epicor.Mfg.UI.FrameWork
> Imports Epicor.Mfg.UI.ExtendedProps
> Imports Epicor.Mfg.UI.FormFunctions
> Imports Epicor.Mfg.UI.Customization
> Imports Epicor.Mfg.UI.Adapters
> Imports Epicor.Mfg.UI.Searches
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> Private WithEvents ctrl as EpiCheckBox
> Sub InitializeCustomCode()
> ctrl = CType(csm.GetNativeControlReference("ca5ec522-471d-40c0-a5a1-a54b62d4f41d-1"), EpiCheckBox)
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
> '// Begin Wizard Added Variable Intialization
> '// End Wizard Added Variable Intialization
> '// Begin Custom Method Calls
> '// End Custom Method Calls
> End Sub
> Sub DestroyCustomCode()
> ctrl = Nothing
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> Private Sub ReportForm_Load(ByVal sender As object, ByVal args As EventArgs) Handles ReportForm.Load
> '// Add Event Handler Code
> ctrl.Checked = True
> End Sub
> End Module
