Customization
I'm still trying to figure this out. I think bw2868bond got me almost there. Thanks for your help! Does anyone else have a suggestion not that I can hook into the paint event? I'll try anything.
Thanks!
--- In vantage@yahoogroups.com, "scottkreel" <skreel@...> wrote:
> Hooking into the paint event seems to partially work. It allowed me to change the sortby and style drop down boxes, but it's not quite working yet. Although the drop down boxes change, it would appear that the values of these drop down boxes that are passed to the crystal report do not change. The style and sortby of the report that is generated is that of the defaults, not of the changes made in the paint event.
> I tried using the SelectedRow property of the EpiUltraCombo control instead of the ActiveRow, but that didn't seem to work either.
> I'm more of a c#/asp.net person, so 'm not as up to date on how binding and everything works in a windows form app.
> Any suggestions would be greatly appreciated. I'll post the outcomes whether successful or not.
> --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > Try this
> > '// Custom VB.NET code for StockStatusReportForm
> > '// Created: 3/26/2009 8:06:05 PM
> > Imports System
> > Imports System.Data
> > Imports System.Diagnostics
> > Imports System.Windows.Forms
> > Imports System.ComponentModel
> > Imports Microsoft.VisualBasic
> > Imports Epicor.Mfg.UI
> > Imports Epicor.Mfg.UI.FrameWork
> > Imports Epicor.Mfg.UI.ExtendedProps
> > Imports Epicor.Mfg.UI.FormFunctions
> > Imports Epicor.Mfg.UI.Customization
> > Imports Epicor.Mfg.UI.Adapters
> > Imports Epicor.Mfg.UI.Searches
> > Module Script
> > '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
> > '// Begin Wizard Added Module Level Variables **
> > '// End Wizard Added Module Level Variables **
> > '// Add Custom Module Level Variables Here **
> > Private WithEvents cboSortBy As EpiUltraCombo
> > Sub InitializeCustomCode()
> > '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
> > '// Begin Wizard Added Variable Intialization
> > '// End Wizard Added Variable Intialization
> > '// Begin Custom Method Calls
> > '// End Custom Method Calls
> > End Sub
> > Sub DestroyCustomCode()
> > '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
> > '// Begin Wizard Added Object Disposal
> > '// End Wizard Added Object Disposal
> > '// Begin Custom Code Disposal
> > '// End Custom Code Disposal
> > End Sub
> > Private Sub StockStatusReportForm_Load(ByVal sender As object, ByVal args As EventArgs) Handles StockStatusReportForm.Load
> > '// Add Event Handler Code
> > cboSortBy = CType(csm.GetNativeControlReference("066cedf0-4e3b-4dfa-873f-747cd2e2e3ed"), Epicor.Mfg.UI.FrameWork.EpiUltraCombo)
> > End Sub
> > Private Sub cboSortBy_Paint(ByVal Sender As Object, ByVal Args As System.Windows.Forms.PaintEventArgs) Handles cboSortBy.Paint
> > '// ** Place Event Handling Code Here **
> > cboSortBy.ActiveRow = cboSortBy.Rows(cboSortBy.Rows.Count-1)
> > End Sub
> > End Module
> > --- In vantage@yahoogroups.com, "scottkreel" <skreel@> wrote:
> > > We created another menu item. So we have two menu items for the same report. We want one to have certain defaults and we want the other to have different defaults. The problem is, when I set the defaults in one, it changes the defaults in the other. If there is a way where I can have separate defaults for each menu item, that would work too.
Ok, I figured it out. I had to change the ReportParameter Data Object settings.
Dim [edvVarName] As EpiDataView = CType(oTrans.EpiDataViews("ReportParam"), EpiDataView)
[edvVarName].dataView([edvVarName].Row)("ReportStyleNum") = 3
[edvVarName].dataView([edvVarName].Row)("SortOptions") = "C"
> Thanks!
> > > Try this
> > > Imports System
> > > Imports System.Data
> > > Module Script
> > > End Sub
> > > End Sub
> > > End Sub
> > > End Sub
> > > End Module
I will need to create a calculator in Vantage. The calculator enable me to entered a number and choose the unit of measure. Automatically, I will need that the system say me, the conversion data. I will need for example convert feet in box. What the good method for create this ?
Vantage 8.03.305
Launch calc.exe via a button control (from what ever app you need this in) and pass it the intial info (U/M conversion rate perhaps).
Or just write your own little vb app imbedded in the main app.
--- On Tue, 5/5/09, vantageuser13 <vantageuser13@...> wrote:
Subject: [Vantage] Customization
Date: Tuesday, May 5, 2009, 8:25 AM
Vantage 8.03.305
Hello,
I customize my "Part Tracker" in Order Management and I'd like to use this customization for all part trackers in the system but not going to one by one and change it in Menu Maintanance. I'd like to use this customization automatically. Is anybody know how to do it?
Thank you.
bart.
I don't think its possible. You have to do it for each and every menu item. If anyone knows a better way, I'd love to hear it.
To: Vantage Group <vantage@yahoogroups.com>
Sent: Friday, May 8, 2009 2:31:42 PM
Hello,
Thank you.
bart.
You can use Menu Maintenance to point to the customization wherever part
tracker is in each module - a little work but it does the trick.
Also, you can use Context Menu maintenance to determine which Part
Tracker runs when you right-click on a part. Be sure to check the
customization box on the top right before you search for the program -
otherwise your changes are for you only.
Randy Weber
Of Steven Gotschall
Sent: Friday, May 08, 2009 1:45 PM
Subject: Re: [Vantage] Customization
<mailto:bartoszniemczewski%40yahoo.com> >
<mailto:vantage%40yahoogroups.com> >
Hello,
Thank you.
bart.
I think you can use sub-process maintenance for this. Basically you tell Vantage "every time program x is called, use customization y". You can also say "every time program x is called from program y, used customization z".
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Friday, May 08, 2009 2:45 PM
Hello,
Thank you.
bart.
if possible on the customization on Vantage,for the thumbtack, when I click on this thumbtack, if not possible for reduce the windows ?
I use vantage 8.03.408b
Thanks.
Does anyone know of an easier way or have sample code that queries a table or looks up data in a table without creating a dataset.
Thank You
Jason Moyer
We are using Vantage 8.03.409A with a progress database
What are you wanting to do? In a BPM you could just work with the
dataset brought in by the business object.
Tim Dines
ERP Analyst
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of Jason Moyer
Sent: Wednesday, June 23, 2010 1:31 PM
Thank You
Jason Moyer
Hey, Jason, hope all is well!
If you want to do this visually, check out DbVisualizer
<http://www.dbvis.com/> . It's a pretty cool utility. There is a free
version and a licensed version with enhanced features.
Regards,
Scott Lepley
_____
Jason Moyer
Thank You
Jason Moyer
_
I have buttons with code on the Order Entry screen that extracts information and populates several form letters that we send out to customers. I would like to use the EntryPerson field that contains the userid and query the UserFile table to return the users full name.
Thanks, Jason
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dines, Tim
Sent: Wednesday, June 23, 2010 2:40 PM
Subject: RE: [Vantage] Customization
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Jason Moyer
Thank You
Jason Moyer
Please consider the impact on our environment before printing this e-mail
Use a BPM to dump the userid into OrderHed.Character01
On update
Assign OrderHed.Caracter01=DCD-UserID.
End.
Sent from my Verizon Wireless BlackBerry
Sender: vantage@yahoogroups.com
Date: Wed, 23 Jun 2010 15:32:26
To: vantage@yahoogroups.com<vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Thanks, Jason
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of Jason Moyer
Thank You
Jason Moyer
Oh and then pull youR fields outside the dataset in the UserFile using that as key field
Date: Wed, 23 Jun 2010 20:43:44
To: <vantage@yahoogroups.com>
Reply-To: advantage@...
On update
End.
Thanks, Jason
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of Jason Moyer
Thank You
Jason Moyer
Hi,
I need to add calculated field porel.relqty*partuom.netvolume in po form.I'm trying to calculate this using BPM.I do not see PArtUOM in temp table.How do I get PArtUOM in temp table?
Also What is the best way to do this customization?
Thanks.
--- In vantage@yahoogroups.com, "Anitha" <anithayedavalli@...> wrote:
> Hi,
> Thanks.
I wouldn't do this via a BPM. Doing so would mean that you've got to store
the field on the table, and then you'd need to make sure that whenever one
field gets updated, the calculated field also does. Doing so isn't good
practice.
I'd recommend you simply add a control to your form, then calculate the
field within your UI. I'd probably put the code in the epidataview
notification sub (use the wizard to create this), others may have a better
idea. You may need to also have some "after field changed" events that
trigger as well (again, use the wizards to create these).
HTH,
Kevin Simon
Anitha
Sent: Tuesday, March 15, 2011 2:51 PM
Subject: [Vantage] Re: Customization-PO
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Anitha"
> Hi,
> Thanks.
Hi Kevin,
I put the calculation in both epidataview
> notification and field change event but for some reason the calculation doesnt seemed to trigger.
The calculated field is placed in POEntry for under lines->detail.
Whenever poline is selected the calculated field should display the result.
Any ideas on how to achieve this?
> practice.
> HTH,
> Kevin Simon
> Anitha
> <anithayedavalli@> wrote:
> > Hi,
> > Thanks.
Anitha,
Go ahead and export your customization and send it to me offline. I'll take
a quick look and see what you're doing.
Kevin Simon
Anitha
Sent: Thursday, March 17, 2011 8:24 PM
Hi Kevin,
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Kevin
> practice.
> HTH,
> Kevin Simon
Behalf Of
> Anitha
> > Hi,
> > Thanks.
