Dasboard multi-selection filter
No. It needs to be 2 different values -- like 2 different states codes such as "CA, TX".
Essentially the filter needs to be [State] CONTAINS ('CA', 'TX').
BUT, the Dashboard Prompt does not allow this keyword. AND, there is no available ListBox control for specifying filters either.
--- In vantage@yahoogroups.com, Mark Wagner <mjfw2003@...> wrote:
> If you use a wildcard such as matches, it will return records with anything containing those values. So for instance, if you wanted to return records for part numbers with matches *123* you would get part records, for 12345, 1234, 12345678, etc
> ÂÂ
> Is that what you are looking to do?
> From: tomdomurat <tomdomurat@...>
> To: vantage@yahoogroups.com
> Sent: Monday, September 10, 2012 1:30 PM
> Subject: [Vantage] Dasboard multi-selection filter
> ÂÂ
> Looking for a way to allow multiple selected values on a singular filter within a dashboard.
> Either a multi-selection combobox/listbox or away of doing a "IN" or "CONTAINS" in the dashboard prompt. Neither is available in the developer mode of dashboards.
Â
Â
