Yes, this will be the solution that works…
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Stan Chmura
Sent: Wednesday, February 20, 2013 3:30 PM
Subject: RE: [Vantage] Dashboard Filter by Date Range
Thanks for the reply! In other posts there were methods suggested that I had already tried unsuccessfully. This is something new! I will try it!
Stan
This communication is intended only for use by the addressee(s) named herein and may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. or the Export Administration Regulations. Export of this material is restricted cannot be exported to foreign persons or foreign destination without prior written approval from the U. S. Department of State or the US Department of Commerce.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark Wagner
Sent: Wednesday, February 20, 2013 4:23 PM
Subject: Re: [Vantage] Dashboard Filter by Date Range
Create a tracker view on your dashboard using the date field you want for the range. Check Honor Prompts and then use greater than or equal to for that field. After you create the tracker field, right click and select customize tracker view. From the toolbox menu, select date/time combo box and add it to your tracker view next to your date range. In the customization properties, select the field and then for is tracker query control select = True. It will then open up the fields you want to use. Select the date field you originally used in your tracker. Under honor dashboard prompts select True and then set your compare to less than or equal to.
Close out of customization view and on your tracker your will have a date range
From: stanchmura schmura@...<mailto:schmura%40fiberoptix.com> >
Sent: Wednesday, February 20, 2013 4:06 PM
Subject: [Vantage] Dashboard Filter by Date Range
I need a dashboard using the BookDtl table that can be filtered by a date range. It would be just like the one in the system dashboard called PO status. Does anyone know how to do this?
Stan
Stan
Stan
