Its looking for a BAQ Data Source. Here are the instructions. If you need the IW Install Guide I can send that to you
Â
On the Portal server:
Make sure you are logged onto the operating system
as Windows user who is member of the Portal
Administrators group (this group is administered
using Portal Administration Console). The Windows
account should also be a member of the
Administrators group on the domain of the computer
on which Portal is installed.
2 Click Start + Programs + Epicor Software +
Epicor Administration Tools + Epicor Portal
Administration Console.
Expand the http node of the Portal server used for
IW.
3 Right-click the Data Sources folder underneath the
Epicor BAQ data source type and select Create Data Source
Â
IW.
--- On Thu, 4/30/09, pilotgl <pilotgl@...> wrote:
Subject: [Vantage] Data Source - Information Worker
Date: Thursday, April 30, 2009, 11:22 AM
I am trying to finish up the tail end of configuring Information Worker. In the Epicor Administration Console after pointing to yoru server they want you to setup a Data Source. I have setup a data source DSN to the database on my SQL server that I am assuming they are referring to. But everytime I go to verify in EAC it tells me that it can't be found or can't find a aspx file. This tells me it wants a IIS site setup almost. Anyone able to help me get this configured?
Greg Lankston
