Database Backups E9
Ah do you mean backups using a backup software?
You need to backup Epicor db etc first, then back that backed up file up (but exclude several folders from the main backup - one being the DB folder - it stuggles backing up a moving target).
Sent: Wednesday, 16 May 2012, 21:49
Subject: [Vantage] Re: Database Backups E9
Â
Do you exclude your \db directory when you do your full backups?
--- In vantage@yahoogroups.com, "r.morton03" <r.morton03@...> wrote:
> So, we backup the whole server every night. The online method of Epicor progress files only is what freezes the app server. We can't do it offline because our shop is running 3 shifts, 24/7/365, and are always going in and out.
> So, does anyone know what the DB Replication is? Found it in the Epicor Admin Console... heh
> --- In vantage@yahoogroups.com, "tracy.tmat" <tracy.smith@> wrote:
> > We work the same as Chris... our online backup runs a couple of times a day and our offline runs on a Sunday afternoon.
> > --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@> wrote:
> > > We have an ONLINE and OFFLINE backup.
> > > The Online one can be ran at any time without shutting down the APPS or DB.
> > > The Offline one shuts down the APPS and DB.
> > > From: r.morton03 <r.morton03@>
> > > Sent: Monday, 14 May 2012, 14:38
> > > ÂÂ
> > > Hi Chris,
> > > Shutting down the app servers. IS that standard operating procedure? We can't isolate the error, it happens whenever it wants.
> > > Thanks
> > > > I dont fully understand what you are asking here.
> > > > Are your backups taking too long or is it just because it is shutting your app servers?
> > > > Thanks.
> > > > Sent: Monday, 14 May 2012, 13:49
> > > > Subject: [Vantage] Database Backups E9
> > > > ÂÂÂ
> > > > This is a little above my knowledge level, but what is happening is we have issues with backing up the database, it shuts down the app servers. Here is the script:
> > > > @echo off
> > > > Rem This is a batch file to backup your Progress 10.1c database
> > > > Rem You will need one of these files for each database you want to backup
> > > > Rem You will need to edit the SET statements for your installation
> > > > Rem Do not edit anything other than the SET statements
> > > > Rem Edit below -----------------------------------------------
> > > > Rem set your Progress directory, using only the physical path
> > > > SET XPrgsDir=d:\epicor\oe101c
> > > > Rem set your Database file, using only the physical path
> > > > SET XDbFile=d:\epicor904\db\mfgsys
> > > > Rem set your backup file and backup log file, using only a physical path
> > > > SET XBackupFile=d:\backups\Live\LiveBkup.2
> > > > SET XBackupLogFile=d:\backups\Live\LiveBkupLog2.wri
> > > > Rem Do Not edit below -----------------------------------------
> > > > Rem Run backup
> > > > Call %XPrgsDir%\bin\probkup online %XDbFile% %XBackupFile% >> %XBackupLogFile%
> > > > Rem Run verification of backup
> > > > Call %XPrgsDir%\bin\prorest %XDbFile% %XBackupFile% -vp >> %XBackupLogFile%
> > > > Rem blank the variables out, since we are finished with them
> > > > SET XPrgsDir=""
> > > > SET XDbFile=""
> > > > SET XBackupFile=""
> > > > SET XBackupLogFile=""
> > > > We found that if we backup the files only once a night, it works just fine, rather than the whole db.
> > > > Anyone have any similar experiences? Suggestions?
> > > > [Non-text portions of this message have been removed]
@echo off
Rem Run backup
SET XPrgsDir=""
SET XDbFile=""
SET XBackupFile=""
Thanks.
Â
@echo off
Rem Run backup
SET XPrgsDir=""
SET XDbFile=""
SET XBackupFile=""
Hi Chris,
> Thanks.
> From: r.morton03 <r.morton03@...>
> ÂÂ
> @echo off
> Rem Run backup
> SET XPrgsDir=""
> SET XDbFile=""
> SET XBackupFile=""
That's definitely not SOPÂ…. It shouldn't be shutting down your appservers.
When you say, "We found that if we backup the files only once a night, it
works just fine, rather than the whole db."
Can you clarify?
r.morton03
Sent: Monday, May 14, 2012 9:38 AM
Hi Chris,
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Chris
app servers?
> Thanks.
> Â
Here is the script:
> @echo off
> Rem Run backup
%XBackupLogFile%
%XBackupLogFile%
> SET XPrgsDir=""
> SET XDbFile=""
> SET XBackupFile=""
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2171 / Virus Database: 2425/4998 - Release Date: 05/14/12
I have never seen the backup bat file stop the appservers.
I vaguely remember a problem once when some backup software was first installed.
I think it locked a file and appserver issues.
We run the batch file to create the backup files.
Use the backup software to backup those backup files - not anything in the database directory.
> @echo off
> Rem Run backup
> SET XPrgsDir=""
> SET XDbFile=""
> SET XBackupFile=""
Â
Hi Chris,
> Thanks.
> ÂÂ
> @echo off
> Rem Run backup
> SET XPrgsDir=""
> SET XDbFile=""
> SET XBackupFile=""
> ÂÂ
> Hi Chris,
> Thanks
> > Thanks.
> > ÂÂÂ
> > @echo off
> > Rem Run backup
> > SET XPrgsDir=""
> > SET XDbFile=""
> > SET XBackupFile=""
> > ÂÂ
> > Hi Chris,
> > Thanks
> > > Thanks.
> > > ÂÂÂ
> > > @echo off
> > > Rem Run backup
> > > SET XPrgsDir=""
> > > SET XDbFile=""
> > > SET XBackupFile=""
Mostly data cubes for reporting functions
Rob Bucek
Production Control Manager
D&S Manafacturing
M: (715) 896-0590<tel:7158960590>
P: (715) 896-0590<tel:7158960590>
Sent from my Verizon Wireless Droid
-----Original message-----
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wed, May 16, 2012 17:25:41 GMT+00:00
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "tracy.tmat" <tracy.smith@...> wrote:
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Chris Thompson <chriselectrix@> wrote:
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Â
> > Hi Chris,
> > Thanks
> > > Thanks.
> > > ÂÂ
> > > @echo off
> > > Rem Run backup
> > > SET XPrgsDir=""
> > > SET XDbFile=""
> > > SET XBackupFile=""
Reply to sender<mailto:r.morton03@...?subject=Re%3A%20Database%20Backups%20E9> | Reply to group<mailto:vantage@yahoogroups.com?subject=Re%3A%20Database%20Backups%20E9> | Reply via web post<http://groups.yahoo.com/group/vantage/post;_ylc=X3oDMTJwaTkzbjBzBF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRtc2dJZAMxMTAyMzkEc2VjA2Z0cgRzbGsDcnBseQRzdGltZQMxMzM3MTg5MTM4?act=reply&messageNum=110239> | Start a New Topic<http://groups.yahoo.com/group/vantage/post;_ylc=X3oDMTJjM2RwYzRsBF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRzZWMDZnRyBHNsawNudHBjBHN0aW1lAzEzMzcxODkxMzg->
Messages in this topic<http://groups.yahoo.com/group/vantage/message/110035;_ylc=X3oDMTM2NTB2a2RvBF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRtc2dJZAMxMTAyMzkEc2VjA2Z0cgRzbGsDdnRwYwRzdGltZQMxMzM3MTg5MTM4BHRwY0lkAzExMDAzNQ--> (8)
Recent Activity:
Visit Your Group<http://groups.yahoo.com/group/vantage;_ylc=X3oDMTJjc28xZTNyBF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRzZWMDdnRsBHNsawN2Z2hwBHN0aW1lAzEzMzcxODkxMzg->
(2) To search through old msg's goto: <a href="http:
> > > ÂÂ
> > > Hi Chris,
> > > Thanks
> > > > Thanks.
> > > > ÂÂÂ
> > > > @echo off
> > > > Rem Run backup
> > > > SET XPrgsDir=""
> > > > SET XDbFile=""
> > > > SET XBackupFile=""
Or online backup script looks different to the one that was posted - we backup each day to a different folder (so the files dont get overwritten) - we then have an email that fires to tell us it has finished.
Here is ours ....
echo Running Epicor live ONLINE Backup...
@echo off
e:\epicor904\oe101c\bin\_mprshut e:\epicor904\db\mfgsys -C backup online e:\epicor904\backed_up_files\live\Friday\live_online_backup_fri.1 %4 %5 %6 %7 %8 %9 >> e:\epicor904\backed_up_files\live\Friday\live_online_backup_fri.Wri
echo Running Verify...
@echo off
e:\epicor904\oe101c\bin\_dbutil prorest e:\epicor904\db\mfgsys e:\epicor904\backed_up_files\live\Friday\live_online_backup_fri.1 -vp >> e:\epicor904\backed_up_files\live\Friday\live_online_verify_fri.wri
@echo off & setlocal
:: set the temp file location
set tempmail=%temp%\tempmail.%random%.txt
:: echo the basic headers to the temp file
echo To: "Backup Users" ^<backup.users@companydomain^> > %tempmail%
echo From: "Backup Programme" ^<no-reply@companydomain^> >> %tempmail%
echo Subject: Friday - Epicor 9 Live Online Backup >> %tempmail%
:: echo the blank line that separates the header from the body text
echo.>>%tempmail%
:: echo the body text to the temp file
echo The Friday backup for Epicor 9 (Live) Online backup has taken place.>> %tempmail%
echo Please check the 'backup' and 'verify' documents (using Wordpad) for any errors - \\server\epicor904\backed_up_files\live\Friday.>> %tempmail%
echo If there are any errors present, please consult with the other Backup Users.>> %tempmail%
:: move the temp file to the mail pickup directory
:: adjust this location for your system
move %tempmail% C:\Inetpub\mailroot\Pickup
set tempmail=
endlocal
This works no problem for us.
Sent: Wednesday, 16 May 2012, 18:25
Â
> > ÂÂ
> > Hi Chris,
> > Thanks
> > > Thanks.
> > > ÂÂÂ
> > > @echo off
> > > Rem Run backup
> > > SET XPrgsDir=""
> > > SET XDbFile=""
> > > SET XBackupFile=""
