Default Buyer - BAQ Table Field
Does anyone know what table.field would contain the default buyer at the part level? Before my time, default buyers were set up at the part level rather than part class, and it’s causing missed items on PO suggestions.
I’m trying to find default buyers at the part level in a BAQ table field, then DMT those to null, and change it to part class, but I can’t find the corresponding field in part plant or anywhere else I’ve looked.
It’s actually in the PartPlant table… PartPlant.BuyerID
The description for that states that it is a buyer assigned to the part class, rather than the part level, and when I used that field, it returned no results.
In all honesty I’ve never used the field at the PartPlant level. There is an additional field on the PartClass table as well, it’s quite probably that the description is incorrect.
