Using Vantage 8.03.409C, I have a BAQ Report Def where I'd like the user
to have default dates show up in the date range fields e.g. Start Date:
a year ago from today for the report.
This is an Option Field in
the BAQ report designer based on a user defined table's column from the
database (and so no adapters etc are available). I see a column for 'Default' on the 'Option Fields' screen
but it doesn't seem to work for a default calculated date.
Just don't know where and using what syntax, I would code for this field?
Please advise.
Thanks in advance.
