Definitions/Help in Customization screen
Does anyone know how to control the definition/help that can appear at the bottom of the customization screen? @Banderson shared a screen shot that had it, but mine does not. See clip below.
Curious why you need to change that text? That is built into the Customization dialog. In theory, you may be able to modify the language settings…
Looking back at it now, bad choice of words.
Does anyone know how to turn the appearance of that on.
It is not on in mine.
Try placing your mouse at the bottom where the text SHOULD be and see if you can drag it up to be visible.
You may also want to purge your personalizations if that fails.
