I know this is way too late for you. Sorry about that.
I had the same question and saw your (unanswered) post.
Here is the solution I found. Simply put the following in the shortcut:
"<path to Client\MfgSys.exe>" [/CONFIG=<pilot_test>.mfgsys] /db /d="<Dashboard ID>"
Note: the brackets are for the optional DB parameter for Pilot, Test, etc.
I hope this will help somebody, somewhere, sometime...
Yves
Yves
--- In vantage@yahoogroups.com, "drew.pete" wrote:
> Hi all,
> I'm on version 9.05.602A and am looking to create a desktop shortcut to my dashboard assembly that I deployed where it opens only the dashboard form itself and not the entire application. Has anyone done something like this?
> Thanks,
> Drew
