I have a post processing BPM that I am running on creation of a sales order Line. It has a condition to fire off of a pre-processing directive.
I need to know what order line was created, and when I set it in the pre-processing directive, it is still 0.
Would something like this work?
var vDbOrderdtl = (from x in erpContext.Db.OrderDtl where x.Company == "Company" && x.OrderNum== callContextBpmData.Number04 && x.OpenLine==true select x).LastOrDefault();
It has been my experience when you’re using the Post-Processing directives, that only the record that was updated is available in the tt table. Example, you have two lines on a SO and are adding a third line. If you query your ttOrderDtl table in the pre-processing, you’d see:
Line 1 with rowmod blank
Line 2 with rowmod blank
Line 0 with rowmod “A”. This is what it’s adding.
After Epicor does it’s update, here’s what’s available in the post-processing directive:
Line 3: rowmod blank (because it’s already been added.
So, on the post method, it should just be the only tt record that’s out there for OrderLine.
As an FYI, updates work a little similar. On the PRE: you’d still have lines 1 and 2 with a blank rowmod. However, you’d see two Line 3’s there: a rowmod blank (the before image) and a rowmod “U” (the updated record. Again, on the post, you’d see just the updated line 3 and rowmod would be blank as that has been committed to the DB.
My safe harbor: please test this. For every rule in how things work in Epicor, you’ll find exceptions. I’m quite sure Order Entry follows this process, but I seem to remember things like inventory transfer does not. It’s been this way since the early days of BPM’s (super-procedures), so it should be pretty safe.
Looks like the ds.OrderDtl table contains all lines in the post processing directive.
Below code returns the correct record that was just created
var vorddtl = (from x in ds.OrderDtl where x.Company == callContextClient.CurrentCompany && x.OrderNum== callContextBpmData.Number04 select x).LastOrDefault();
