Development server....so close I can taste it
Your PF is missing the references to the DB and such if local on the sever
it should look something like this
-disabledeltrig
-Mm 1024 -mmax 65534 -Bt 4096 -s 8000 -yy 1970 -stsh 31 -inp 32000 -tok
4000 -TB 31 -TM 32 -D 500 -l 1000 -ttmarshal 5 -tmpbsize 8 -rereadnolock
-lkwtmo 180
-T "C:\epicor\EpicorData"
-db "C:\epicor\Epicor905\db\newdb\mfgsyssh"
-db Epicor905 -dt MSS -ld mfgsys -Dsrv
PRGRS_CONNECT,DSN=Epicor905,TXN_ISOLATION,1,PRGRS_NATIVE_LOCKWAIT,30000,PRGRS_NOWAIT_OVERRIDE,1
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Wed, Nov 2, 2011 at 3:52 PM, Nick <nick@...> wrote:
> This is the PF file that is on my admin workstation.
> -disabledeltrig
> 4000
> -lkwtmo
> 180
> -T "C:\DEVEpicor905\Server\config\cs"
> -cpinternal utf-8 -cpstream utf-8 -cprcodein utf-8 -cpcoll icu-uca
> my servername is devepicor. I am doing a single server install on Server
> 2008R2 with SQL 2008 64 non unicode.
> On Wed, 2 Nov 2011 15:09:18 -0400
> Jose Gomez <jose@...> wrote:
> Check your PF File and make sure that the settings are
> correct? SQL Or
> Progress?
> If SQL make sure your ODBC is setup right and the PF file
> reflects it
> Check your Epicor.ini file (DLC Path needs to be pointing
> to your OE
> install)
> If you want copy and paste your PF file here if you have
> doubts as yo what
> should look like.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Wed, Nov 2, 2011 at 2:52 PM, Nick <nick@...>
> wrote:
> > So I am to the point for a schema change.
> > I am getting an error when I try to launch the admin
> >tools.
> > DataAdminMenu.w Database Mfgssh not connected. (1006)
> > ** Unbable to run startup procedure DataAdminMenu.w.
> >(492)
> > So close. ...so close.
> > Anyone have any ideas?
> Useful links for the Yahoo!Groups Vantage Board are: (
> Note: You must have already linked your email address to
> a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for
> Report Builder and Crystal Reports and other 'goodies',
> please goto: http://groups.yahoo.com/group/vantage/files/.
> (3) To view links to Vendors that provide Vantage
> services goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups
> Links
I am getting an error when I try to launch the admin tools.
** Unbable to run startup procedure DataAdminMenu.w. (492)
Check your PF File and make sure that the settings are correct? SQL Or
Progress?
If SQL make sure your ODBC is setup right and the PF file reflects it
Check your Epicor.ini file (DLC Path needs to be pointing to your OE
install)
If you want copy and paste your PF file here if you have doubts as yo what
should look like.
*Jose C Gomez*
*Software Engineer*
E: jose@...
Are you performing a single or split (sql and app on separate dev machines) install?
-disabledeltrig
-Mm 1024 -mmax 65534 -Bt 4096 -s 8000 -yy 1970 -stsh 31 -inp 32000 -tok 4000
-TB 31 -TM 32 -D 500 -l 1000 -ttmarshal 5 -tmpbsize 8 -rereadnolock -lkwtmo
180
correct? SQL Or
Progress?
reflects it
to your OE
install)
doubts as yo what
should look like.
*Jose C Gomez*
*Software Engineer*
E: jose@...
>tools.
>(492)
services goto:
Links
