Please unsubscribe me from this digest.
Thank you,
Jennifer Vahdati
jvahdati@...
[mailto:vantage@yahoogroups.com]
Sent: Monday, March 12, 2001 10:21 AM
Subject: [Vantage] Digest Number 1214
------------------------ Yahoo! Groups
Sponsor ---------------------~-~>
Find software faster. Search more than 20,000
software solutions on KnowledgeStorm. Register
now and get started.
http://us.click.yahoo.com/7u_SwA/zMSCAA/Ig4EAA/P0AVlB/TM
---------_->
There are 25 messages in this issue.
Topics in this digest:
1. 'Easy on the eye' Crystal forms
2. RE: [off topic] Closing Dos Batch File Windows
3. RE: [off topic] Closing Dos Batch File Windows
4. RE: [off topic] Closing Dos Batch File Windows
<jimstetter@...>
5. Re: Label Printers and RB
6. Citrix - error message
7. RE: Citrix - error message
8. Re: Citrix - error message
9. Getting the discount amount
10. Re: [off topic] Closing Dos Batch File Windows
11. Re: 'Easy on the eye' Crystal forms
12. [off topic] Closing Dos Batch File Windows
13. Re: 'Easy on the eye' Crystal forms
<dhieber@...>
14. Crystal 8
15. RE: 'Easy on the eye' Crystal forms
16. RE: Crystal 8
17. Re: Crystal 8
18. RE: Citrix - error message
19. RE: Re: Crystal 8
20. RE: 'Easy on the eye' Crystal forms
21. Re: 'Easy on the eye' Crystal forms
22. RE: 'Easy on the eye' Crystal forms
23. RE: Citrix - error message
24. Re: Citrix - error message
25. RE: Citrix - error message
____________________________________________________________
____________
____________
Message: 1
Date: Mon, 12 Mar 2001 12:26:45 +0000
Subject: 'Easy on the eye' Crystal forms
Hi all,
I designed a set of Crystal forms for P/O's, Subcon P/O's,
Despatch Notes and Invoices that all print on the same
pre-printed paper on an HP laser printer. This paper is
sorted by the supplier into alternate white and yellow
copies, so that we can print 2 copies of each of these. This
works very well indeed for us, saves on different
pre-printed forms, and saves on form complexity & print
time. I would be happy to post the design of each of the
Crystal forms, and the CorelDraw design of the pre-printed
paper, if anyone is seriously considering changing their
forms setup. They are neat and very readable! The only
slight drawback, of course, is that they are customized to
suit our company, and we use the odd field in an
unconventional manner. Plus we are a UK based company, so
obviously the forms are UK orientated.
I will keep an eye out for responses, and post the designs
if there are a few requests.
++ Andy Watts
++ Ripley Engineering Ltd
++ Tel: 01256-473940
++ Fax: 01256-479991
++ mailto: andy@...
____________
____________
Message: 2
Date: Mon, 12 Mar 2001 07:08:44 -0600
Subject: RE: [off topic] Closing Dos Batch File Windows
On Windows 95 and 98 machines. When you first run a DOS
application on that
computer it creates a PIF file (in your Windows\PIF
directory). If you open
the PIF file properties, there is a check box for "close on
exit". I don't
know the reason but the default is unchecked, thus leaving
the DOS window
open. Check it and the window will close when the DOS app
ends.
Michael Podlin
Sent: Sunday, March 11, 2001 6:48 PM
To: Vantage
Subject: [Vantage] [off topic] Closing Dos Batch File
Windows
Does anyone know how to make a DOS batch file that
automatically closes the
DOS window after it is done? Is there a DOS command to do
this?
Troy Funte
Liberty Electronics
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
____________
____________
Message: 3
Date: Mon, 12 Mar 2001 08:08:05 -0500
Is this a batch file? I have found if a launch a CMD or BAT
file, they close
when they are done even if I don't put in an EXIT command.
If it is a batch
file, check to make sure the last command is actually
finishing by putting a
PAUSE command after the last line. If the batch file stops
to wait for a key
press, then at least you know the previous command is
finishing.
Brian Boyes,
Systems Administrator,
Precision Resource Canada Ltd.
<http://www.precisionresource.com>
<mailto:brianb@...>
____________
____________
Message: 4
Date: Mon, 12 Mar 2001 08:17:46 -0500
Try putting EXIT as the last line of the batch file (or the
last line to be
executed)
Jim S.
Sent: Sunday, March 11, 2001 7:48 PM
To: Vantage
Windows
the DOS window after it is done? Is there a DOS command to
do this?
Troy Funte
Liberty Electronics
Yahoo! Groups Sponsor
Click Here to Find Software Faster
Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
____________
____________
Message: 5
Date: Mon, 12 Mar 2001 09:21:32 -0500
Subject: Re: Label Printers and RB
Is anyone using these type of printers (Zebra, Tharo, etc)
with Report Builder Reports? If so, how did you configure
them to work? Thanks.
Tim Care
Electro Chemical Finishing
Thank you,
Jennifer Vahdati
jvahdati@...
---------_->
<jimstetter@...>
<dhieber@...>
14. Crystal 8
16. RE: Crystal 8
17. Re: Crystal 8
____________
____________
Message: 1
Hi all,
++ Andy Watts
++ mailto: andy@...
____________
____________
Message: 2
application on that
exit". I don't
the DOS window
ends.
Michael Podlin
To: Vantage
Windows
this?
Troy Funte
Liberty Electronics
____________
____________
Message: 3
> Does anyone know how to make a DOS batch file that"exit"
> automatically closes the DOS window after it is done? Is
> there a DOS command to do this?
file, they close
If it is a batch
to wait for a key
finishing.
Brian Boyes,
<mailto:brianb@...>
____________
____________
Message: 4
last line to be
executed)
Jim S.
To: Vantage
Windows
do this?
Troy Funte
Liberty Electronics
of Service.
____________
____________
Message: 5
Tim Care
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, March 09, 2001 10:07 AM
Subject: [Vantage] Label Printers
> We want to install a printer in our shipping department to
just print
labels
> from Vantage. I am assuming that this can be done. What
printers are
others
> using to do this? Also, are there any "gotchas" to watch
out for? Thank
you.
> Peter McGuire
> Lovejoy Chaplet Corp.
> pmcguire@...
> (518) 686-5232
> Fax: 686-4919
____________
____________
Message: 6
Date: Mon, 12 Mar 2001 09:48:57 -0500
Subject: Citrix - error message
All of a sudden this morning, we started getting the
following error message
when trying to connect to Vantage over Citrix. This is
occurring for all
Citrix sessions, local or over the T1 and we get to error
when connecting
directly to Vantage locally.
"The system cannot find the path specified. Failing
component:
V:\progress\bin\prowin32.exe
v:\vantage\db\vantage.db -ininame
v:\vantage\vantage.ini -pf v:\vantage\db\vantage.pf -N
TCP -S vantage -H
nmclinton -p mainmenu.w"
Does anybody have any ideas as to what may be causing this?
We didn't
change anything on our workstations or on the cotrix server
over the
weekend?
Thanks!
Sarah
____________
____________
Message: 7
Date: Mon, 12 Mar 2001 08:48:43 -0600
Subject: RE: Citrix - error message
Sarah,
Make sure your mapped drive is still in place on the
citrix server, if
so, remove the mapping and remap again. I've experienced
this same problem a
few times myself.
Nick
[mailto:sarah.vareschi@...]
Sent: Monday, March 12, 2001 8:49 AM
Subject: [Vantage] Citrix - error message
occurring for all
when connecting
component:
TCP -S vantage -H
We didn't
over the
weekend?
Thanks!
Sarah
<http://rd.yahoo.com/M=162801.1342103.2934627/D=egroupmail/S
=1700007183:N/A=
599089/*http://www.knowledgestorm.com/jump_white.html?c=Yaho
o&n=eLert_Comput
ersInternet_Software_WhiteGridOptions&t=ad> Click Here to
Find Software
Faster
<http://us.adserver.yahoo.com/l?M=162801.1342103.2934627/D=e
groupmail/S=1700
007183:N/A=599089/rand=457695842>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
____________
____________
Message: 8
Date: Mon, 12 Mar 2001 15:42:25 -0000
Subject: Re: Citrix - error message
You may also need to reinstall the Vantage Client. That
also seems
to fix a lot of the errors. Let me know if any of these
fixes your
problem. We use Citrix at are place also.
--- In vantage@y..., "Robinson, Nick" <nrobinson@o...>
wrote:
> Sarah,
citrix
server, if
this same
problem a
> few times myself.
> Nick
> From: sarah.vareschi@n... [mailto:sarah.vareschi@n...]
> To: vantage@y...
following
error message
occurring
for all
when
connecting
component:
TCP -S
vantage -H
this? We
didn't
server over the
> weekend?
> Thanks!
> Sarah
=170000718
3:N/A=
c=Yahoo&n=eLert_Comput
Find
Software
> Faster
M=162801.1342103.2934627/D=egroupmail/S=1700
of Service
____________
____________
Message: 9
Date: Mon, 12 Mar 2001 15:44:53 -0000
Subject: Getting the discount amount
I'm trying to create a sales by state report, and I can get
it to
work. The only problem is I'm not getting the discounts.
Does
anybody have any idieas or reports created that give you
what your
sales were for each state with the discounts.
Ken Devorak
____________
____________
Message: 10
Date: Mon, 12 Mar 2001 10:48:36 -0500
Subject: Re: [off topic] Closing Dos Batch File Windows
Exit didn't close the window on the batch file until I
selected Properties on the DOS box and checked "Close on
Exit". Now it closes fine.
Thanks for the help Mike, Brian, and Jim
Troy Funte
Liberty Electronics
To: Vantage
Windows
Troy Funte
Liberty Electronics
of Service.
____________
____________
Message: 11
Date: Mon, 12 Mar 2001 10:50:10 -0500
Subject: Re: 'Easy on the eye' Crystal forms
So you print the "pre-printed" forms inhouse? Nice idea. I
would like to see the CorelDraw documents, if possible.
Troy Funte
Liberty Electronics
Sent: Monday, March 12, 2001 7:26 AM
Subject: [Vantage] 'Easy on the eye' Crystal forms
Hi all,
++ Andy Watts
++ mailto: andy@...
of Service.
____________
____________
Message: 12
Date: Mon, 12 Mar 2001 07:56:46 -0800
Subject: [off topic] Closing Dos Batch File Windows
Troy, Try entering a line with the word "exit" in it. That
should close out
the window..
Lyal Shoff
Processor/MIS
Hanard Machine Inc.
859 7th St. NW.
Salem, Oregon 97304
Phone: 503-364-3952
Fax: 503-364-6895
____________
____________
Message: 13
Date: Mon, 12 Mar 2001 11:45:38 -0500
> Good Idea. I would like to see the forms and the corel
draw files. I never thought about pre-printing in house.
Dina
> Hi all,
P/O's, Despatch Notes and Invoices that all print on the
same pre-printed paper on an HP laser printer. This paper is
designs if there are a few requests.
> ++ Andy Watts
> ++ mailto: andy@...
of Service.
____________
____________
Message: 14
Date: Mon, 12 Mar 2001 11:45:56 -0500
Subject: Crystal 8
Is it necessary to upgrade to Crystal 8 for Release 5.0, or
can you still
use
Crystal 7?
Thanks for the info.
Joy Fekkes
Jaco, Inc
140 Constitution Blvd.
Franklin, MA 02038
____________
____________
Message: 15
Date: Mon, 12 Mar 2001 11:48:42 -0500
Subject: RE: 'Easy on the eye' Crystal forms
Andy,
We have been talking about how to handle this recently. We
would like
see the forms and CorelDraw design. If you don't get enough
response,
would you email direct?
Thanks in advance,
Steve Wirtz
Sent: Monday, March 12, 2001 7:27 AM
Hi all,
pre-printed paper
on an HP laser printer. This paper is sorted by the supplier
into
alternate white and yellow copies, so that we can print 2
copies of each
of these. This works very well indeed for us, saves on
different
time. I would be
happy to post the design of each of the Crystal forms, and
the CorelDraw
design of the pre-printed paper, if anyone is seriously
considering
changing their forms setup. They are neat and very readable!
The only
suit our
company, and we use the odd field in an unconventional
manner. Plus we
are a UK based company, so obviously the forms are UK
orientated.
if
++ Andy Watts
++ mailto: andy@...
------------------------ Yahoo! Groups Sponsor
____________
____________
Message: 16
Date: Mon, 12 Mar 2001 11:42:03 -0500
Subject: RE: Crystal 8
I was told that upgrading to version 8 was a must before we
went to
version5
Sent: Monday, March 12, 2001 11:40 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Crystal 8
can you
still
use
Crystal 7?
Joy Fekkes
Jaco, Inc
Franklin, MA 02038
____________
____________
Message: 17
Date: Mon, 12 Mar 2001 17:30:22 -0000
Subject: Re: Crystal 8
If you plan on modifying reports, yes you need version 8.
or can you
still
> use
> Crystal 7?
> Joy Fekkes
> Jaco, Inc
> Franklin, MA 02038
____________
____________
Message: 18
Date: Mon, 12 Mar 2001 12:50:10 -0500
I tried unmapping and mapping the V drive again. Then I
tried uninstalling
and re-installing. that worked, however, that caused errors
for all the
users not on citrix. So, I reinstalled another user
workstation and that
fixed the problem for the straight users but now the citrix
users are
getting the error message again. Now I think it's because
our vntgwork
folder is on the C drive for our regular workstations, but
on the citrix
server there is no c, the c is the n. Does anybody know How
I can install
this on to the n without screwing up all the ones that hit
the c????
____________
____________
Message: 19
Date: Mon, 12 Mar 2001 12:50:32 -0500
Subject: RE: Re: Crystal 8
The key word here is MODIFYING.
Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty
St. Ext.
Meadville, PA 16335 814-333-6331 x236 fax: 814-337-2548
tlw@...
<mailto:tlw@...> www.chipsco.com
<http://www.chipsco.com/>
[mailto:jloonelist@...]
Sent: Monday, March 12, 2001 12:30 PM
Subject: [Vantage] Re: Crystal 8
or can you
still
> use
> Crystal 7?
> Joy Fekkes
> Jaco, Inc
> Franklin, MA 02038
=1700007183:N/A=
599088/*http://www.knowledgestorm.com/jump_white.html?c=Yaho
o&n=eLert_Comput
ersInternet_Software_WhiteGridTime&t=ad>
Service
____________
____________
Message: 20
Date: Mon, 12 Mar 2001 12:50:07 -0500
Andy,
Same here,
Dave Cole
Reeder & Kline
Sent: Monday, March 12, 2001 11:49 AM
Subject: RE: [Vantage] 'Easy on the eye' Crystal forms
Andy,
would like
response,
Thanks in advance,
Steve Wirtz
forms
Hi all,
P/O's,
pre-printed paper
into
copies of each
different
time. I would be
the CorelDraw
considering
The only
suit our
manner. Plus we
orientated.
designs if
++ Andy Watts
++ mailto: andy@...
=1700007183:N/A=
o&n=eLert_Comput
Find Software
Faster
groupmail/S=1700
007183:N/A=599089/rand=646495503>
Service
____________
____________
Message: 21
Date: Mon, 12 Mar 2001 13:00:40 -0500
Andy:
I'll add to the list of folks. I'd like to see your forms
as well. My forms
have taken some heat over readability so this is right up my
alley.
Thanks!
Rick Gors
MR/MMIS
Osco
"Cole, Dave" wrote:
> Andy,
> Same here,
> Dave Cole
> Reeder & Kline
> From: Steve Wirtz [mailto:SWirtz@...]
> Andy,
We would like
enough response,
> Thanks in advance,
> Steve Wirtz
> From: Andy Watts [SMTP:andy@...]
forms
> Hi all,
P/O's,
pre-printed paper
supplier into
copies of each
different
time. I would be
the CorelDraw
considering
readable! The only
suit our
manner. Plus we
orientated.
designs if
> ++ Andy Watts
> ++ mailto: andy@...
=1700007183:N/A=
o&n=eLert_Comput
Find Software
> Faster
groupmail/S=1700
of Service
____________
____________
Message: 22
Date: Mon, 12 Mar 2001 13:14:55 -0500
Andy, will you be posting these? Otherwise I would
appreciate seeing them.
As we are moving to release 5.0 this month, might be a good
time to change
bob goss
bc instruments
bobg@...
Sent: March 12, 2001 1:01 PM
Subject: Re: [Vantage] 'Easy on the eye' Crystal forms
Andy:
as well. My
forms
alley.
Thanks!
Rick Gors
MR/MMIS
Osco
"Cole, Dave" wrote:
> Andy,
> Same here,
> Dave Cole
> Reeder & Kline
> Andy,
We would like
enough response,
> Thanks in advance,
> Steve Wirtz
forms
> Hi all,
P/O's,
pre-printed paper
supplier into
copies of each
different
time. I would be
the CorelDraw
considering
readable! The only
suit our
manner. Plus we
orientated.
designs if
> ++ Andy Watts
> ++ mailto: andy@...
=1700007183:N/A=
o&n=eLert_Comput
Find Software
> Faster
groupmail/S=1700
of Service
____________
____________
Message: 23
Date: Mon, 12 Mar 2001 12:11:32 -0600
Create two separate .vtg files then you can change one
without affecting the other.
Hope this helps,
Oleg
[SMTP:sarah.vareschi@...]
Sent: Monday, March 12, 2001 11:50 AM
Subject: RE: [Vantage] Citrix - error message
tried uninstalling
for all the
users are
our vntgwork
on the citrix
I can install
the c????
____________
____________
Message: 24
Date: Mon, 12 Mar 2001 13:20:56 -0500
There are 2 options -
1) Create a New VTG file that is the same as the
Vantage.vtg file, but with the vntgwork location as N,
and then use that VTG file to start vantage.
2) If you start vantage with a command line, make sure
that the location of vntgwork is N: for your citrix users.
Tim Care
Sent: Monday, March 12, 2001 12:50 PM
tried
uninstalling
errors for all the
citrix users are
our vntgwork
on the citrix
How I can install
the c????
____________
____________
Message: 25
Date: Mon, 12 Mar 2001 13:28:53 -0500
Thanks. I can do that. But I am running Vantage over
citrix using a
published application, so I don't know if that will work for
me. Does
anybody have their Citrix drives different? Can you tell me
how your is set
up? You published application line? Thanks,
Sarah
____________
____________
