We are currently running 10.1.400.37 and we are going up to 10.2.300.0. And many of the dept. heads want to know what has changed between those versions. Where do I find that info? I am hoping this doesn’t mean I have to go over every upgrade paper and wee, but if I do, I will.
The realease notes will help they usually have a brakdown of all changes between all the versions… (long read)
@Mark_Wonsil I have 10.2.300 in my test environment but I cannot find the Feature summary. In 10.1.400 I just had to click on the Help tile and then feature summary. But that is not an option in my 10.2.300, at least there is no Help tile to click.
Yeah, I am not in the Modern Shell. How do I go to the modern shell?
When you login, uncheck Classic and Active desktops.
Ahh, SSO here. So, nothing to change, it just auto comes up.
Hi will,
Have you got multiple application servers on your E10 install all using SSO ? IE live , test , pilot.
I have an issue setting the system agents, saying I could not use a duplicate imported AD account for the system agent. Which got me very frustrated
Hey Lee! I do have multiple applications, but its only Pilot and Live. My test is in a separate VM reaching back to the SQL database. I never had that issue with what I was doing. If you say No, what doe sit do?
