Roger,
We are in the process of testing out the DMR process. Based on the testing, if you select debit memo instead of credit the cost will flow back to the returns account.
Deirdre Sykes
Staff Accountant
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Butler, Bruce
Sent: Monday, December 05, 2011 3:44 PM
Subject: RE: [Vantage] DMR Processing
Roger,
I am not 100%, but believe this is an override. If you let it go, it will either default to the returns account attached to the part's product group. If that is not setup, it will bounce to the system default setup in your company configuration's control accounts.
Bruce Butler, IS Manager
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of roger.clark88
Sent: Monday, December 05, 2011 9:03 AM
Subject: [Vantage] DMR Processing
I'm working through DMR Processing. When goods are rejected a DMR is created and credit memo requested. The goods are written off, awaiting a Supplier Credit. The problem I have is that the Credit Memo is treated as a misc credit and the debit coded to GRNI (the default). Although the system cross references the DMR with the Credit Memo (via actions menu) it doesn't automatically assign a GL code to the returns account. Do I just manually code it and am I expecting too much of the system to code it automatically?
CONFIDENTIALITY: The information contained in this email message, including any attachment(s), may be privileged and confidential and protected from disclosure. The email is not intended for transmission to, or receipt by, any unauthorized persons. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication or use of the information contained herein is strictly prohibited. If you have received this electronic mail transmission in error, please delete it from your system without copying or disseminating, and notify the sender by Reply email, so that our address record can be corrected.
Deirdre Sykes
Staff Accountant
Roger,
