DMT for MOM? Blank Title 116097
The changes though engineering workbench would yes.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jim Chance
Sent: 27 November 2012 13:10
Subject: Re: [Vantage] DMT for MOM?
Stephen, would these steps be performed through the DMT/Engineering/BOM selection?
>________________________________
> From: Stephen Edginton <stephene@...<mailto:stephene%40dotnetit.co.uk>>
>To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
>Sent: Monday, November 26, 2012 9:33 PM
>Subject: RE: [Vantage] DMT for MOM?
>Yes, if say you wanted to swap a part you provide the mtlSeq and new part number and it will allow you to swap the part, you only need to pass one row into DMT to do this.
>If you want to remove items you need to create a separate import file that will just to the deletes.
>But you can in effect make any changes you want, add reference designators, add co parts.
>Relate items to operations, change QtyPers etc.
>You can also do this to Jobs and quote methods.
>Regards,
>From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of jim_chance
>Sent: 26 November 2012 22:17
>To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
>Subject: [Vantage] DMT for MOM?
>Can DMT be used to update methods?
>Structure?
>For instance where the MOM needs to have an additional part # in the BOM.
>Or for when the part # in the method is wrong, can this data be updated via DMT?
>[Non-text portions of this message have been removed]
Structure?
Regards,
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jim_chance
Structure?
> From: Stephen Edginton <stephene@...>
>To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
>Regards,
>Structure?
Hi Jim,
I am currently importing some new BOMs into a test db using DMT (running as I’m writing this!). I have created 4 imports for adding a new revision, adding operations, adding materials and unapproving the old revision.
The revision is done through Inventory – Part – Part Revision.
The Operations are done through Engineering – Bill Of Operations.
The Materials are done through Engineering – Bill Of Materials.
Rather than start from scratch, I use Crystal to grab the data for the current revision/operations/materials. Export the reports to excel. Modify the data/add to the data as required and then import into a test db for checking before updating the live db. You can also use access or excel to export the data, in this instance I just thought Crystal was the easiest tool.
I would use the same process for updating an existing revision.
Hope this helps.
Regards,
Darryn
> From: Stephen Edginton <stephene@... <mailto:stephene%40dotnetit.co.uk> >
>To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> " <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
>Regards,
>From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of jim_chance
>To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>Structure?
